Valve Clearance Question in a B18c4
Old Nov 11, 2004 | 09:02 AM
crxste's Avatar
Default Valve Clearance Question in a B18c4
Hello,
I have a B18c4 (same as a B18c1) and I'm thinking of rebuilding the bottom end with a set of EK9 pistons to bump the compression up a fair bit over stock, goes to around 12.2:1 AFAIK.
I'm running a GSR head with EK9 cams and Ti Springs & retainers, with a stock head gasket.
Will I have any valve clearance problems with this set up?
Also If I have the head milled by 20thou would that set up be fine?
Cheers guys
Old Nov 11, 2004 | 11:03 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Valve Clearance Question in a B18c4 (crxste)
i hate this question however ctr pistons in a gsr block with ctr cams should be no problem but to be sure you should check piston to valve clearance (with vtec locked up)
hondafan62269
Feb 21, 2006 07:05 AM
Tech6023
Sep 12, 2005 09:26 PM
temp
Jul 25, 2004 01:50 PM
McFly
Mar 2, 2003 08:01 PM
knighteg
Aug 27, 2002 02:15 PM
