Quick question on SeaFoaming for my EM1
Old Nov 11, 2004 | 03:32 AM
Declectic's Avatar
Default Quick question on SeaFoaming for my EM1
I'm gonna seafoam my Si this friday . . .
if someone could kindly draw a circle around the brake booster line i should unplug
i've read plenty of DIYs but all of the brake booster lines look different and i just want to make sure i'm doing this **** right
thanks in advance
Old Nov 11, 2004 | 03:48 AM
hondaracing1's Avatar
Default Re: Quick question on SeaFoaming for my EM1 (SeanJohn1802)
not really a good enough picture to circle the correct one needs somethin a lil closer to the firewall
Old Nov 11, 2004 | 04:22 AM
JDMH22HATCH's Avatar
Default Re: Quick question on SeaFoaming for my EM1 (hondaracing1)
Its the large vacuum line on the back of the mani that goes up and then curves right to the brake booster.
Old Nov 11, 2004 | 04:27 AM
poison's Avatar
the biggest hose that connects to the back of your manifold that goes towards the driver side in front of your brake master cylinder.
Old Nov 11, 2004 | 04:29 AM
Declectic's Avatar
Default Re: Quick question on SeaFoaming for my EM1 (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">Its the large vacuum line on the back of the mani that goes up and then curves right to the brake booster. </TD></TR></TABLE>
okay, thats what i thought. i just wanted to make 100% sure, i'll take another picture . . to be 200% sure
Old Nov 11, 2004 | 04:33 AM
nighttrain33's Avatar
Please search.
https://honda-tech.com/zero...age=2
-Shane
Old Nov 11, 2004 | 04:34 AM
Declectic's Avatar
So with that line, disconnect it from the master cylinder on the firewall, and let it soak up some seafoam right into the intake mani right? just double checking myself before i wreck myself
Default Re: Quick question on SeaFoaming for my EM1 (nighttrain33)
Sorry that came out wrong. There is a picture in the link just so you can make sure which one we are talking about. Scroll down a little bit and you will see it.
-Shane
Old Nov 11, 2004 | 04:35 AM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">Please search.
-Shane</TD></TR></TABLE>
Shane -
I did.. i actually viewed that thread, he said he wasnt sure if it was the same because of his GSR mani . . so i'm just double checking since i have a b16 mani
thanks for help guys. i just wanted to be confident in going into this when i do it on friday
yeah i dont have that on my firewall, thats why i asked and made a thread
Old Nov 11, 2004 | 04:45 AM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
im interested in this too....
and u should be 200% sure...u dont want another "wheel polishing" incident
Old Nov 11, 2004 | 04:48 AM
Declectic's Avatar
Default Re: Quick question on SeaFoaming for my EM1 (DivisionSix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DivisionSix &raquo;</TD></TR><TR><TD CLASS="quote">and u should be 200% sure...u dont want another "wheel polishing" incident </TD></TR></TABLE>
hahaha, ****. . HT now knows me as that guy! lol
i'll be doing a write up this friday, hopefully all goes well, i got an oil leak, so i plan to do the seafoam, and i go ta new oil pan gasket, gonna replace that and all new screws, hopefully that fixes it.. if not . . once i pay off my credit cards ima just send the hsit to honda and say fix it!
Old Nov 11, 2004 | 04:53 AM
I know that our motors don't have that intermediate attatchment. Just follow the same line all the way to the firewall and pull the clip and then the line. When you pour the seafoam in, go slowly. Good luck.
-Shane
Old Nov 11, 2004 | 04:55 AM
Declectic's Avatar
right on, thanks bro
Old Nov 11, 2004 | 07:05 AM
Ya@inlinePRO's Avatar
sounds so scary...
Old Nov 11, 2004 | 07:11 AM
Luserkid's Avatar
Default Re: (kwik2nec)
https://honda-tech.com/zerothread?id=1016891
Maybe that would help you if you still dont know where to put the rest of the stuff.
Old Nov 11, 2004 | 07:29 AM
Deemeetree's Avatar
Electrician
Just pull the hose from the picture above. Measure 1/3 bottle and SLOWLY SLOWLY pour in. If you go too quick it'll bog down and sound as if you were sucking in water. It took me about 7 minutes to pour the 1/3 bottle in. Your idle WILL be jumping up and down, so don't worry. Turn the car off and let it sit.
Fortunately, I had NO smoke at all come out. I guess my piston tops are pretty clean.
Old Nov 11, 2004 | 07:49 AM
tuoniz's Avatar
I just did mine 4 days ago. 1/4 bottle in my oil, and the rest in my gas tank and intake manifold. I just used a vacuum line on the intake mani on by jdm b16. It smoked for like 15 mintues strait. My throttle response feels better and it seems i'm getting better gas milage.
Old Nov 11, 2004 | 08:08 AM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">
EM1's have a check valve built into the hose. Not really hard to tell where it is. It's a hump in the hose. But yeah, do like everybody else already said. Either disconnect the hose from the brake booster or another thing you can so is to unhook the brake booster line from the intake manifold and use a small funnel to dump the fluid into the port that way.
Or hell, even better idea, just pull that little 1/4" line off your cruise control (actually off the little black plactic cylinder next to your clutch fluid cylinder and suck it in using that.
Old Nov 11, 2004 | 09:17 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: (SeanJohn1802)
HAPPY TREE FRIENDS!
Old Nov 11, 2004 | 09:31 AM
usdmike's Avatar
sorry, off topic... Is that flippy?
Old Nov 11, 2004 | 12:03 PM
Declectic's Avatar
you know it!! HTF &gt; me
cityofcaterpillars
Jun 12, 2010 02:15 AM
uses0ap
Sep 21, 2008 08:19 PM
JDM_SOHC
Mar 24, 2008 10:10 PM
JDubya
Dec 30, 2003 02:13 PM
