WHat is the Proper way to connect a ground?
Old Nov 10, 2004 | 09:19 PM
Rob_Dog's Avatar
Default WHat is the Proper way to connect a ground?
I was wondering what the best way of hooking up ground wires is, does it help if it's connecting to bare metal opposed to painted metal, also what if your not using one of those wire connectors instead you just wrap the wire around a bolt and screw it down, will this affect grounding performance?
Old Nov 10, 2004 | 09:25 PM
eda6's Avatar
Default Re: WHat is the Proper way to connect a ground? (Rob_Dog)
Get a meter and check continuity from a painted surface to bare metal. You won't have continuity. The paint acts as an insulator resulting in an open circuit and no current flow.
Not using a connector is half *** imo and will not work as good.
Old Nov 10, 2004 | 09:27 PM
Rob_Dog's Avatar
Default Re: WHat is the Proper way to connect a ground? (eda6)
So then it's good to have it connected to bare metal?
Old Nov 10, 2004 | 09:33 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob_Dog &raquo;</TD></TR><TR><TD CLASS="quote">So then it's good to have it connected to bare metal?</TD></TR></TABLE>
it's essential.
Old Nov 10, 2004 | 09:34 PM
Rob_Dog's Avatar
thanks for the info
Old Nov 10, 2004 | 09:36 PM
kim_2_da_chee's Avatar
Don't just wrap the wire around the screw.
Properly insert the wire into proper terminal and screw the terminal down.
Yes, bare metal is best.
Old Nov 10, 2004 | 10:12 PM
drussell4801's Avatar
WTF!?
Old Nov 10, 2004 | 10:46 PM
Rob_Dog's Avatar
Default Re: WHat is the Proper way to connect a ground? (drussell4801)
WTF,
Old Nov 11, 2004 | 02:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote"> The paint acts as an insulator resulting in an open circuit and no current flow.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">The paint acts as an insulator resulting in an open circuit and no current flow.</TD></TR></TABLE>
Leo.
Nov 8, 2006 03:03 PM
tallyturbo
Welding / Fabrication
11
Dec 26, 2005 02:27 PM
EM1VtecSi
Feb 18, 2005 02:19 PM
AspectIndustries
Oct 3, 2004 05:09 PM
TAG
Jul 23, 2002 03:19 AM
