which one is safer?? wet nos kit or dry zex kit??
Old Dec 25, 2001 | 06:38 AM
v-tec crx's Avatar
New User
Default which one is safer?? wet nos kit or dry zex kit??
which one is a safer kit?? thanks
Old Dec 25, 2001 | 06:43 AM
DragII's Avatar
Default Re: which one is safer?? wet nos kit or dry zex kit?? (v-tec crx)
Dry Zex, IMO
w/ no more than a 50shot should be quite safe.
Old Dec 25, 2001 | 08:37 AM
KawiGreenVTEC's Avatar
Default Re: which one is safer?? wet nos kit or dry zex kit?? (DragII)
I would say dry ZEX only for one reason, you are limited to how big of a shot you can use, but any N2O setup is safe as long as you adjust your fuel delivery to match your N20 delivery and adjust your spark accordingly as well.
Old Dec 25, 2001 | 08:55 AM
94HybridEX's Avatar
Default Re: which one is safer?? wet nos kit or dry zex kit?? (KawiGreenVTEC)
What is difference between wet and dry?
Old Dec 25, 2001 | 09:26 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: which one is safer?? wet nos kit or dry zex kit?? (94HybridEx)
ZEX kit, for dry shot.
Old Dec 25, 2001 | 10:41 AM
WykidEH's Avatar
As long as you keep it reasonable, NOS is the ****! I've used it for years w/no probs. . . . .
Old Dec 25, 2001 | 11:52 AM
Dry shot inject N2O only through the nozzle, fuel pressure may or may not be increased at the regulator depending on the system you are using.
Wet shot injects N2O and extra fuel through the same nozzle.
Old Dec 25, 2001 | 02:45 PM
gsrvx's Avatar
New User
I really don't know anything about NOS...but does that mean that a wet system is safer....since it provides the extra fuel?
Old Dec 25, 2001 | 03:07 PM
Default Re: which one is safer?? wet nos kit or dry zex kit?? (RK)
Not always wet systems are usually larger shots so they require more fuel, dry shots do not offer extra fuel because of their delivery they do not require it.
Old Dec 25, 2001 | 05:06 PM
gsrvx's Avatar
New User
What's the biggest shot you'd go for with a dry kit? The reason I ask is that I'm going for a h22 swap soon...and some people tell me that lude motors respond well to nos. I guess I should start researching on dry, wet, direct port, plate systems, etc.
Old Dec 25, 2001 | 06:47 PM
H22 I would do a Direct port 80 shot at a minimum H22 blocks are very strong, My buddy is running a 75 dry shot on his
Old Dec 25, 2001 | 09:21 PM
gsrvx's Avatar
New User
thx man.
Old Dec 25, 2001 | 11:43 PM
Mista Bone's Avatar
D Tranny Guru
Honda intake not designed to flow wet fuel, go dry or a true direct port setup.
Old Dec 26, 2001 | 06:19 AM
GoQkRaCeR's Avatar
go with a Direct kit.. but WET is safer.. more fuel mixture. ive installed many wet kits on hondas.
itrhatch
Mid-Atlantic (Sales)
Sep 5, 2006 01:00 PM
eg six
May 29, 2006 05:45 PM
djtony5
Feb 24, 2006 01:03 PM
BlackRocket
Oct 9, 2004 07:48 AM
MooreBoost
Feb 18, 2004 10:18 AM
