-3an oil line too small for VTEC?
Old Dec 24, 2001 | 06:57 PM
HX_Guy's Avatar
Default -3an oil line too small for VTEC?
Im currently running a BSPT fitting off the rear of the block to a -3an line, then to a T fitting which goes to my oil pressure gauge and to my stock sensor.
Can I also use -3an line for the VTEC feed? Or is it too small? Should I run -4an off the block and to the head?
The thing is, the 1/8" BSPT off the block is TINY! I mean the hole in the fitting is like a -2an. I get 80+ PSI above 4000 RPMs which is more then enough to activate VTEC.
Old Dec 25, 2001 | 12:07 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: -3an oil line too small for VTEC? (HX_Guy)
Gotta luv fluid dynamics and no ENDYN BBS!
#3 or #4, you'll never know the difference
Old Dec 25, 2001 | 12:32 AM
sgT's Avatar
sgT
1/8 is about the same as -4
Old Dec 25, 2001 | 06:06 AM
HX_Guy's Avatar
Default Re: -3an oil line too small for VTEC? (Mista Bone)
Haha...Im having withdrawls here without the Endyn board ;-)
So youre saying it should be ok? I dont know...Im just paranoid, everyone uses -4.
Is the line just to provide pressure to kick VTEC on or does it provide oil to the head/cams?
Old Dec 25, 2001 | 08:21 AM
rainforest's Avatar
iam to when is it coming back??
madcrx69
Apr 17, 2010 05:31 AM
AJxr
Jul 27, 2009 02:27 PM
b20b
Feb 22, 2002 03:46 AM
b20b
Feb 22, 2002 03:45 AM
HX_Guy
Dec 24, 2001 11:03 PM
