Tuning?
Old Nov 9, 2004 | 04:49 PM
91DroppedHatch's Avatar
Default Tuning?
Ok if anyone out there can please clear this up for me. What exactly is "tuning" I know I sound really really stupid but I have no idea, im reading things like tuning the ECU and fuel and like you need a the ECU to be chipped in order to use hondata but I thought hondata was a chip. I have no idea, sl basically if anyone can clear up "tuning' and hondata for me I would be so happy, thank you. Yes I searched and found nuthing.
Old Nov 9, 2004 | 06:11 PM
burnout289's Avatar
Default Re: Tuning? (91DroppedHatch)
http://www.hondata.com/
tuning is exactly what it sounds like: tuning the engine to get the most power/performance/efficiency as possible. this may include changing the timing, reprogramming the ECU to remove the speed limiter, raise the rev limiter and adjusting the air/fuel mixture. why not do a search on here for "tuning"? on older cars, it may be as simple as timing and adjusting the carburetor.
anytime you have a question, search till your fingers bleed. then ask questions to fill in the gaps. http://www.google.com comes in handy as well.
Old Nov 9, 2004 | 07:08 PM
Default Re: Tuning? (burnout289)
thank you, thats kinda what I figured tuning was, I thought it was more complicated than that, so all id have to do is setup the engine then tow it to a tuner, then have him adjust things to make it drivable. Thanx
Old Nov 10, 2004 | 06:51 AM
burnout289's Avatar
if you have any planned bolt-ons [header/muffler/intake manifole/etc] do those first, then get the car dyno-tuned. as the name implies, it's where you set the car on a dyno and they tune it till you have the best power curve you can with your setup.
rrace002
Engine Management and Tuning
Sep 20, 2011 08:23 PM
imonx850
Jan 5, 2005 09:19 PM
jdm4show
May 22, 2004 11:51 PM
VtecInteg95
Dec 11, 2002 08:29 PM
C-speed
Nov 30, 2001 10:49 PM
