z6 block = a6 block?
Old Nov 9, 2004 | 12:43 PM
si_hatch's Avatar
Default z6 block = a6 block?
I was just wondering if the d16z6 block is the same as the z6 block. Right now i have a z6 in my car and i have a spare a6 and I plan on having it sleeved so i just want to make sure that there are the same and that it will work out. Thanks
Old Nov 9, 2004 | 02:57 PM
civicsitek GanGsTa's Avatar
Default Re: z6 block = a6 block? (si_hatch)
a6>z6. a6 block has steel mains. If you sleeve a block sleeve the a6.
Old Nov 9, 2004 | 07:15 PM
si_hatch's Avatar
Default Re: z6 block = a6 block? (civicsitek GanGsTa)
i won't have to drill any oil lines for vtec will i? Cuz i will still be using the z head
Old Nov 9, 2004 | 07:31 PM
Bailhatch's Avatar
all you do is pull a little restrictor plug out of the deck surface. Much easier than a ls vtec in that respect.
Old Nov 9, 2004 | 08:44 PM
si_hatch's Avatar
Default Re: z6 block = a6 block? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">all you do is pull a little restrictor plug out of the deck surface. Much easier than a ls vtec in that respect.</TD></TR></TABLE>
So other than that everything will work, valve clearances and what not. I just want to make sure before i go and drop a whole lot of money into this.
Old Nov 9, 2004 | 11:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
So other than that everything will work, valve clearances and what not. I just want to make sure before i go and drop a whole lot of money into this.</TD></TR></TABLE>
Yes, compression will be slightly higher w/ the z6 head though. Here
http://www.knology.net/~jediklc/D.htm Compression will be about .6 higher with the z6 head.
soodominican
Mar 9, 2009 07:49 PM
xerokill
12
Sep 7, 2007 05:41 AM
dkrex001
Sep 6, 2006 07:58 AM
19crx88
Nov 17, 2005 03:11 AM
Mr. Self Destruct
Apr 20, 2005 01:34 PM
