Got fuel and spark, car wont start
Old Dec 24, 2001 | 02:45 PM
Turbolude's Avatar
Default Got fuel and spark, car wont start
I have spark, and i have fuel to the rail. The car wont start. Havent really troubleshooted it to much, i just figured I would start by posting on here. As of right now im thinking injectors or something along those lines. What effect does splicing the resistor pack wires with butt connectors have. I know that there is a certain resistance that must be maintained, but how would this effect it from starting? Any thoughts. By the way this is a 92 Si prelude motor in my 93 Vtec Prelude. I am using the engine harness for the si, and the ecu for the si. Any thoughts?
Old Dec 25, 2001 | 02:21 PM
Perfectionist's Avatar
Default Re: Got fuel and spark, car wont start (Turbolude)
With the ignition on, you should have 12 volts at the injectors (the ECU completes the path to ground for each injector at the right time). The resistors just limit the current to the injectors. That's necessary because of their design (you won't get more hp by bypassing them). Check your wiring for bad (open) connections.
Old Dec 25, 2001 | 04:11 PM
Turbolude's Avatar
Default Re: Got fuel and spark, car wont start (Perfectionist)
Injectors are firing and working properly. Car still wont start. what is the deal?
Old Dec 25, 2001 | 04:31 PM
carsaregood's Avatar
ignition timing? cam timing? got the firing order all correct and in the right places on the distributor?
Old Dec 25, 2001 | 08:10 PM
Turbolude's Avatar
Default Re: Got fuel and spark, car wont start (carsaregood)
this is all correct.
Old Dec 26, 2001 | 01:24 AM
Is the cam/distributor turning? (Timing belt)
Old Dec 26, 2001 | 06:42 AM
Crazydave's Avatar
do you have cylinder pressure?
how is your timing?
Old Dec 26, 2001 | 10:32 AM
chi1874436's Avatar
Default Re: Got fuel and spark, car wont start (Crazydave)
check distributor
check cam/ignition timing
pull fuel rail out with injectors and turn key to see if injectors spray
check firing order
do a compression test
perform a valve adjustment
make sure you are @ TDC
make sure you are not 180 degrees out of time (usually occurs when installing dist. incorrectly)
jump ecu
SIR_DREAM_KID
Feb 22, 2012 05:26 AM
civic46
11
Sep 12, 2010 05:25 PM
lude98SH
Oct 1, 2007 06:15 PM
baldmofo
Oct 19, 2006 08:13 AM
jesse d
Aug 6, 2004 06:19 PM
