ticking valves?
i have a type r head that i just put some skunk2 valves in...i did a valve adjustment about three times and i still hear ticking..it's not my injectors..could it be my rock arms? what else could it be? please help! thanks.
did you do the lash adjustment with a hot motor? also you should have put a set of s2s2 cams because those stock cams aint gonna do **** for those valves so there is really no gain dude. you should seriously consider building yur moter all at once!! yur boy should stick to alignments and oil changes and routine matenance instead of ****** yur shi# up. take it to somebody that has a rep. for building fast motors.. good luck!
