Turbo Question Please Help.....
Old Nov 7, 2004 | 09:33 PM
Got Milk's Avatar
Default Turbo Question Please Help.....
whats up im planning on turbo'n my gsr and i was wondering when i put the kit on is it safe to run stock internals on 6 or 7 PSI daily??? that amount seems good right or could it go up alil more?....cause while im driving my car daily i want alil more torque in it to have alil fun ....if anyone knows please post thanks alot
Old Nov 7, 2004 | 09:49 PM
PhantomSTi's Avatar
Default Re: Turbo Question Please Help..... (Got Milk)
Drag Kit = Bling Pipe, good turbo, crappy wg (now, they all are using Tials), Blitz BOV (My Opinion it's hot), good intercooler, manifold tends to spike, but I've never experienced the spiking personally. Inline Fuel pump + FMU.
Rev Hard = Same thing as above pretty much, except no name stuff (stuff I've really never heard before) good turbo, good bov, good wg, better manifold than the drag, not the bling pipe, Inline fuel pump + FMU.. Pretty much same as above.
Full Race = Hardcore Ish! Everything is pure badass. No cheap fuel management, but when you buy this.. you don't intend to cheap out on fuel management.
FMax = Haven't heard much about it...
I currently am running a Drag Kit, Evo WG, a High Flow Fuel Pump and an FMU and am damn happy with it. If I had the cash I'd get the Full Race, but to answer your question 6-7lbs would be fine on your GSR
Old Nov 7, 2004 | 09:51 PM
virusiidx's Avatar
you may have to upgrade your stock internals since u have a gsr. Some research should help.
Old Nov 8, 2004 | 02:30 PM
Got Milk's Avatar
Default Re: (virusiidx)
i thought 7-8 psi on stock internals is more than safe ?
Old Nov 8, 2004 | 09:58 PM
xtremeness101's Avatar
Default Re: (Got Milk)
im running 9 lbs on my stock gsr but im tuned on hondata.... if i was you, i would buy the turbo kit and then save up the cash and buy a hondata s200b and get some rc 440-550cc injectors and get it tuned properly and then you will not have to worry about it being reliable because it will. But if want to run the FMU that comes with the kit then you are more prone to have something go wrong with the setup bc the FMU are not so reliable especially when/or if you go beyond 7 psi.
Old Nov 9, 2004 | 01:47 AM
SHystrdyGSRtdy's Avatar
Default Re: (xtremeness101)
6-7 psi is fine on stock internals... make sure you get it tuned though.. don't skimp out on that
Old Nov 9, 2004 | 02:25 AM
Khelm's Avatar
Default Re: (SHystrdyGSRtdy)
saftey is all a matter of how much you are willing to spend to get the car tuned. the more you pay the better the tune the higher the psi
Old Nov 9, 2004 | 04:35 AM
Elemental's Avatar
tuned.
Old Nov 9, 2004 | 05:30 AM
qcktegls's Avatar
Default Re: (Kyoushu)
like almost every thread about turbo says. tuning is everything
Old Nov 9, 2004 | 05:42 AM
PLAGUED_DB7's Avatar
Default Re: (qcktegls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qcktegls &raquo;</TD></TR><TR><TD CLASS="quote">like almost every thread about turbo says. tuning is everything</TD></TR></TABLE>
SEARCH...check out the FI fourm
6-7 is ok till you can build up
Old Nov 9, 2004 | 07:57 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Milk &raquo;</TD></TR><TR><TD CLASS="quote">whats up im planning on turbo'n my gsr and i was wondering when i put the kit on is it safe to run stock internals on 6 or 7 PSI daily??? that amount seems good right or could it go up alil more? </TD></TR></TABLE>
You should be more concerned with what kind of power you want to make, not how much boost you're going to run.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90integra05 &raquo;</TD></TR><TR><TD CLASS="quote">Drag Kit = Bling Pipe, good turbo, crappy wg (now, they all are using Tials), Blitz BOV (My Opinion it's hot), good intercooler, manifold tends to spike, but I've never experienced the spiking personally. Inline Fuel pump + FMU.
The Deltagate Mark II wastegate is fine that comes with most Drag Gen III kits. I used it on my old turbo'd B18b and the only time I got boost creep is when I used the poorly designed DRAG manifold. I upgraded to an InlinePro mani and that problem was solved. It's all about wastegate location.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx &raquo;</TD></TR><TR><TD CLASS="quote">you may have to upgrade your stock internals since u have a gsr. Some research should help.</TD></TR></TABLE>
Care to tell him why you think he should upgrade internals? If he doesn't plan on breaking the 300whp barrier, his stock internals would hold up fine for awhile. (driving habits vary per person though.)
Not just turbocharging, but and mild to wild build should be tuned to extract full potential out of it. Even a stock engine could see useful gains by just using a stand-a-lone engine management but itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUED_DB7 &raquo;</TD></TR><TR><TD CLASS="quote">
\check out the FI fourm
Old Nov 9, 2004 | 09:41 AM
virusiidx's Avatar
Default Re: Turbo Question Please Help..... (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Care to tell him why you think he should upgrade internals? If he doesn't plan on breaking the 300whp barrier, his stock internals would hold up fine for awhile. (driving habits vary per person though.).</TD></TR></TABLE>
just to be on the safe side like mine. He didn't ask why. geez
Old Nov 9, 2004 | 12:16 PM
SIK IN DA HED's Avatar
New User
you should be fine using your stock motor with moderate boost. 7-9psi is what we normally boost with a stock motor. anything higher, youre riskin blowin your motor.
enieft
May 7, 2004 07:40 PM
HvyArmzLudeBB6
Jun 11, 2003 03:20 PM
sparq
Dec 18, 2002 01:46 PM
ludelvr
Aug 23, 2002 09:44 AM
SlowB16
Apr 3, 2002 05:47 PM
