does a gsr engine have a knock sensor?
Old Nov 7, 2004 | 07:30 PM
ebrakeracin4's Avatar
Default does a gsr engine have a knock sensor?
Like the title says, does a 94-95 b8c1 gsr engine have a knock sensor?
Old Nov 7, 2004 | 07:33 PM
eda6's Avatar
Default Re: does a gsr engine have a knock sensor? (ebrakeracin4)
yes
Old Nov 7, 2004 | 07:49 PM
Discosteak's Avatar
Default Re: does a gsr engine have a knock sensor? (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>ditto
Old Nov 7, 2004 | 08:38 PM
Sack Master's Avatar
Default Re: does a gsr engine have a knock sensor? (BADEG6)
I 3rd that.
Old Nov 17, 2004 | 03:12 PM
integra95gsr's Avatar
Default Re: does a gsr engine have a knock sensor? (Sack Master)
what does a knock sensor do.. well what the hell is it? i heard something about the v-afc changing it.. what to you benefit from changing it? thank you!
Old Nov 17, 2004 | 03:28 PM
PrettyLude's Avatar
knock sensor will pick up anything abnormal going on inside the block and retard timing so you don't mess anything else up
Old Nov 17, 2004 | 03:33 PM
drdisco69's Avatar
Default Re: does a gsr engine have a knock sensor? (integra95gsr)
https://honda-tech.com/zerothread?id=1047144
Old Nov 17, 2004 | 06:24 PM
sleepin91teg's Avatar
Default Re: does a gsr engine have a knock sensor? (drdisco69)
Keep in mind, Vtec is ran off of a knock sensor, if your knock sensor sends out a voltage higher than specifications, than vtec wont work...
A knock sensor is a sensor that creates a voltage signal under pressure by crystals...so when theres a knock, it pushes on crystals wich creates voltage...and a specific voltage called "pieso electricty"
Old Nov 24, 2004 | 03:16 PM
TurboTeG4's Avatar
Default Re: does a gsr engine have a knock sensor? (sleepin91teg)
What if im running a p28 with a obd2 gsr engine in a 94 gsr and hondata, do I still need to hook up the knock sensor. Can I leave the block with no knock sensor in or do I have to put one in?
Old Nov 24, 2004 | 09:27 PM
Default Re: does a gsr engine have a knock sensor? (TurboTeG4)
NO you don't need to run it as a p28 has no knock sensor.
Old Nov 24, 2004 | 09:49 PM
TurboTeG4's Avatar
But you do have to have it installed?
Old Nov 25, 2004 | 09:19 AM
86si's Avatar
no
untitledsn41
Jul 30, 2004 04:48 AM
DR. ON POINT
Dec 12, 2001 12:26 PM
