**South florida Performance mani...
Old Nov 7, 2004 | 10:26 AM
highboostb18c1's Avatar
Default **South florida Performance mani...
well i can't do any searchs because its unavailable so i have to post.
what does everyone think of the South florida performance manifold?
i have a gsr and have a drag kit that i am upgrading
SFP manifold
Tial 40mm
hondata s200
cp pistons 9.5:1 cr
eagle rods
arp rod and head studs
block gaurd (don't know which one)
gsr cams
port and polish head
and my only other problem is i don't know what turbo to get? this is a daily driver and to make more power then this...
any ideas? to4e? t61? t3/to4e stage 5 wheel 60 trim?
Old Nov 7, 2004 | 10:27 AM
Default Re: **South florida Performance mani... (highboostb18c1)
oh by the way, this is with my drag kit, 440cc inj, vafc2,
Old Nov 7, 2004 | 10:38 AM
b16sedan's Avatar
Run 9:1 compression instead of 9.5 or higher, you really don't gain anything from it. SFP mani is good, I have a lot of DSM friends that run it, and several people on here. Personally I would run a .63 A/R Stage III exhaust side mated up with a 60-1 compressor, it'll make lots of power and the spool is very reasonable.
Old Nov 7, 2004 | 11:53 AM
Sohc Driver's Avatar
Default Re: **South florida Performance mani... (b16coupe)
I run an SFP manifold. I put down 259whp at 211wtq on my stock b18b at 10lbs.
**Setup**
Stock B18b SFP manifold
T3/T04e 57trim .63ar
Greddy Type S BOV
Precision 350hp Intercooler
Fast-Turbo.com Oil lines
2.5inch Downpipe
3inch exhaust/3inch hi-flo cat/3inch resonator/3inch Magnaflow Muffler
Tial 35mm Wastegate
ACT HD street disc clutch/ACT Streetlite flywheel
Magnecore 8.5mm plug wires
NGK 9-step colder plugs
**Engine Management**
Hondata S200b
RC 750cc Injectors
Walbro 255lph-HP fuel pump
Khoi
Old Nov 7, 2004 | 12:58 PM
SIanara's Avatar
was just wondering what everyone thought about the garret t3/60-1 with .63 a/r
or if you have ay other suggestions?
Old Nov 7, 2004 | 04:17 PM
Default Re: **South florida Performance mani... (vteGraGSR)
Old Nov 7, 2004 | 05:48 PM
MooreBoost's Avatar
Your numbers are pretty low and I would chalk it up to the fact that your running the hack. I would stick to what youve got and get it tuned, you shouldn't be dissapointed.
Old Nov 7, 2004 | 06:05 PM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteGraGSR &raquo;</TD></TR><TR><TD CLASS="quote">was just wondering what everyone thought about the garret t3/60-1 with .63 a/r
or if you have ay other suggestions? </TD></TR></TABLE>
good turbo.... I have one for sale that has never been used if anyones interested....
Old Nov 8, 2004 | 04:05 AM
Default Re: **South florida Performance mani... (BoostedEG6)
how much?
Old Nov 8, 2004 | 09:40 AM
vtecdamian's Avatar
did u get the link to the manifold i sent?
rev-speed
Jul 27, 2004 04:06 PM
JBk24crx
Mar 31, 2004 01:10 PM
GEN2TEG
Dec 16, 2002 03:55 AM
93B17A
Jul 1, 2002 08:23 AM
Nov 18, 2001 10:55 PM
