onefab mani w/ stock radi
Old Nov 7, 2004 | 12:18 AM
jdm.ej's Avatar
Default onefab mani w/ stock radi
could i put the one fab mani ac comp in my ej still using my stock radiator??this is the mani ive been hold off putting my turbo on for becuz i dont really want to use the ssautochrome one i got but i dont really feel like paying 800 for the mani then spending another what 250 300 for a radiator. i could be wrong on the price of the radiator. but you know what i mean.if anyone got any input on this please let me know.oh if any interested in the ssauto mani i sell.. thanks
Old Nov 7, 2004 | 02:57 AM
Frozen E's Avatar
H-T White Ops
more than likely you'll have to chop the stock radiator fan shroud to get the turbo to clear. Then if you're going to try to run a real filter that's going to be a whole different headache.
What you could do is buy yourself a couple slim fans from Viren and put one on your radiator and one on your condenser. Then you might be able to run a pipe with a filter on it.
Personally that's what I'm going to try to do. I have a couple on order right now and just waiting for them to get here. In the mean time I'm running window screen over my turbo inlet. I'll have to get some pics up for you guys. I promised them a long time ago but haven't come through yet.
Old Nov 7, 2004 | 07:34 AM
fipracing_com's Avatar
Default Re: onefab mani w/ stock radi (jdm.ej)
Yes you can run the stock radiator with the onefab a/c manifold. If you want to keep the stock fan you will have to cut the stock fan housing some what. I would reccommend that you get a FAL fan for the stock radiator. It is a plug and play install will give you ALOT more room to work with and is fairly inexpensive, as well it will FLOW more air than the stock fan. An upgraded radiator is not necessary, unless you are experiencing overheating with the stock radiator.
Old Nov 7, 2004 | 06:25 PM
jdm.ej's Avatar
Default Re: onefab mani w/ stock radi (fipracing_com)
so i def will have to change the fan.
Old Nov 8, 2004 | 03:27 AM
Yes,
I would as the FAL will pull way more air than stock and with the intercooler blocking up most of the radiators air path you need all the air flow you can get.
Old Nov 12, 2004 | 10:26 PM
integlspwr2k's Avatar
bringing this back up from the dead.
I too will be running the same manifold, but was wondering what size fan should i buy for the condensor side? the rad side will be a 12" but the condensor side should be a 10" or 9".
Matt, the maker for the one fab manifolds said use a 10" but wanted to see what everyones using.
Thanks!
-integlspwr-
Old Nov 13, 2004 | 01:24 PM
Default Re: onefab mani w/ stock radi (integlspwr2k)
anyone?
Old Nov 13, 2004 | 01:33 PM
This One's Avatar
Ive had some people get away with 12" on both sides.
There is a bit less room on some cars on the a/c side.
So thats why i say go with the 10" on the a/c side.
It should easy be sufficent
Old Nov 13, 2004 | 04:10 PM
Im running a FAL #140 pusher fan on my setup for the condenser and it fits no problem, it is tight but it fits. This fan is the same size as the radiator side. I can post some pictures if your are interested. I mounted it right behind the intercooler infront of the condenser, The A/C works great esp on the 90+ Degree day at a stop light.
Matt does great work and the manifold is working out great.
Old Nov 13, 2004 | 06:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fipracing_com &raquo;</TD></TR><TR><TD CLASS="quote">Im running a FAL #140 pusher fan on my setup for the condenser and it fits no problem, it is tight but it fits. This fan is the same size as the radiator side. I can post some pictures if your are interested. I mounted it right behind the intercooler infront of the condenser, The A/C works great esp on the 90+ Degree day at a stop light.
what size is the FAL #140?
I think i might go with the 10" but im leaning torwards the 9" so i guranteed have space for that manifold.
please email me pics at integlspwr@verizon.net
Thanks!
killerpenguin21
Jun 25, 2010 12:13 AM
daddy
Honda Civic (2001 - 2005)
13
Jan 31, 2008 05:25 AM
Ri5e
Jun 19, 2002 07:47 PM
d mafia
Jan 19, 2002 06:26 PM
clendaniel
Nov 6, 2001 04:31 AM
