Full race turbo kit in gsr
hey i was looking into gettin the full-race stage 2 turbo kit for my gsr, heres my mods: Gsr block, golden eagle sleeves, je 9:1 comp pistons, eagle rods, crank kinfe edged , blueprinted, balanced, arp main studs, head studs, stock gsr head, skunk 2 cam gears, aem fpr, 660 rc injectors or 550, 255 fuel pump, gm 3bar map sensor, b16a2 dizzy, stock IM and TB, Hondata s200 with boost option, thinking i can push towards 400whp on about 18psi for the track and about 10psi daily driver? Do you think the T3/60-1 turbo is going ot be enough for these goals?
i think you will get where you want to be , but you should not think boost # ,s think in horse power, boost is erelavint it the power level that matters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hockey27925 »</TD></TR><TR><TD CLASS="quote">hey i was looking into gettin the full-race stage 2 turbo kit for my gsr, heres my mods: Gsr block, golden eagle sleeves, je 9:1 comp pistons, eagle rods, crank kinfe edged , blueprinted, balanced, arp main studs, head studs, stock gsr head, skunk 2 cam gears, aem fpr, 660 rc injectors or 550, 255 fuel pump, gm 3bar map sensor, b16a2 dizzy, stock IM and TB, Hondata s200 with boost option, thinking i can push towards 400whp on about 18psi for the track and about 10psi daily driver? Do you think the T3/60-1 turbo is going ot be enough for these goals? </TD></TR></TABLE>
Why build your motor with low compression and sleeves if you're only going to push 10 psi daily? 400 WHP from a 60-1 should take much less than 18 psi, and you certainly don't need sleeves for 400 WHP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @lbert »</TD></TR><TR><TD CLASS="quote">
Why build your motor with low compression and sleeves if you're only going to push 10 psi daily? 400 WHP from a 60-1 should take much less than 18 psi, and you certainly don't need sleeves for 400 WHP.</TD></TR></TABLE>
Why this why that blah blah babbady blaahhhh, the guy already has a built motor so just let him use it, its better safe than sorry.
Your on the right track dude that 60-1 is plenty good for that combo.
