60 trim turbo output
http://www.rogueusa.com/Garret...0.htm
thats the turbo, .63 a/r non bb. I cant find what its ability is though, its going on a built Gsr motor. 9:1 com cp pistons, eagle h beams (new design), arp main and head studs, stock head for the most part, i am wondering what sort of boost i should run and what kinda power should i expect? (this is my daily not jus track car)
Re: 60 trim turbo output (TheShodan)
and i know its very circomstancial (cant spell for shiv) but what boost is that at? I am going for about 400whp.
Re: 60 trim turbo output (EJ8 GSR-T)
I have the exact same turbo on my daily driven type R. 365 @ 14 psi. on a ls vtec with 9.0 comp and eagle rods with GSR cams. Should be able to make 400 easy with just a 3inch catback with type R cams and 2-3 more psi.
the head is a stock head with skunk 2 stage 1 turbo cams....what kind of power/boost shoudl i be looking at if i want my car to last
Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">Yep. about 440 at about 18-22psi or so depending upon what is used. But you can't just go by that. Just because its maxed out, doesn't mean that's the one that should be used.</TD></TR></TABLE>
what do you mean?
what do you mean?
i also have a t3/t4 60 trim, but it is not installed on my 1.8 motor. I am planning on running between 15-20 psi, what rpm do most of u c full boost at?
Re: 60 trim turbo output (Dstretch33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dstretch33 »</TD></TR><TR><TD CLASS="quote">i also have a t3/t4 60 trim, but it is not installed on my 1.8 motor. I am planning on running between 15-20 psi, what rpm do most of u c full boost at?</TD></TR></TABLE>
would kinda depend on what comp pistions your are runnin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T »</TD></TR><TR><TD CLASS="quote">
would kinda depend on what comp pistions your are runnin</TD></TR></TABLE>
I will be running stock integra ls pistons
