need help i have 340cc RC injectors but they wont fit on a 96-98 civic Ex do i need some thing els
i have a 96 civic i bought some 340cc RC injectors but they wont fit on on wiring part do i need some thing else to make them work i tried to make them fit on a 2000 Si but the wires dont fit 2 is there a special wire that i need
WHY are you putting 340's on? Turbo? Supercharger?
According to what I've read the stock ECU can only handle about up to 310 CC injectors without outside help.
I inherited a motor that had RC's on it. It took rigging to get them to work. Whoever installed them used multiple sealing washers at the manifold end to get them to fit. I went back to stock 240's which, is all I needed to a stock R motor. The RC's used OBD1 harnesses which means the idiot I got the engine from had to butcher the harness to wire in injectors.
i dunno if this will help but i figured to give you a sling shot link..........
http://www.homemadeturbo.com/t....html
I know its for that dsm injector but maybe it will help you with fitting.
tg
tg
Don't bother buying the RC's. Way overpriced. Go to a junkyard and do some looking around. Lots of older cars have the OBD1 style clips. I actually found an old Corvette that I pulled mine off of. Stuck 'em in my pocket and left.
Yeah, I'm a thief. Sue me.
