need help i have 340cc RC injectors but they wont fit on a 96-98 civic Ex do i need some thing els
i have a 96 civic i bought some 340cc RC injectors but they wont fit on on wiring part do i need some thing else to make them work i tried to make them fit on a 2000 Si but the wires dont fit 2 is there a special wire that i need
Re: need help i have 340cc RC injectors but they wont fit on a 96-98 civic Ex do i need some thing
WHY are you putting 340's on? Turbo? Supercharger?
According to what I've read the stock ECU can only handle about up to 310 CC injectors without outside help.
I inherited a motor that had RC's on it. It took rigging to get them to work. Whoever installed them used multiple sealing washers at the manifold end to get them to fit. I went back to stock 240's which, is all I needed to a stock R motor. The RC's used OBD1 harnesses which means the idiot I got the engine from had to butcher the harness to wire in injectors.
i dunno if this will help but i figured to give you a sling shot link..........
http://www.homemadeturbo.com/t....html
I know its for that dsm injector but maybe it will help you with fitting.
tg
tg
You need obdI injector clips. They will not work with your obdII clips. You can buy Rc's clips or You can get obdI clips off of an eg and splice them into your harness....
H-T White Ops
Don't bother buying the RC's. Way overpriced. Go to a junkyard and do some looking around. Lots of older cars have the OBD1 style clips. I actually found an old Corvette that I pulled mine off of. Stuck 'em in my pocket and left.
Yeah, I'm a thief. Sue me.
