Clutch problem
ok guys, so i was in a rush today to get to my class which is a 30 min drive and i had 15 min to get there, so i was gunning it. I was stoped at a stop light and as soon as it turned green i punched it. 1st was fine, but when i went from 1st to 2nd it wouldnt go into gear, so i stuck it into 3rd, then the clutch stayed on the floor. First time its happened, but then it happened again later on today. Anyone know what the problem could be? my clutch or tranny? or maybe soemthing wrong with the hydro lines?
pull the edal off of the floor. rest your foot on it, if it sinks down, chances are you will need a master cylinder. if you can get to the slave, pull the boot back on it and see if there is any fluid leaking there too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">look at the clutch master, check for fluid first. </TD></TR></TABLE>
well, it wasnt happening untill today, and yesterday i topped it off w/ some dot-3, so im thinkin maybe some air got in the lines?
Drizzo
13
Aug 5, 2004 08:44 AM
