Just advanced my timing to 18
Old Dec 23, 2001 | 02:08 PM
Ibuprofen's Avatar
Default Just advanced my timing to 18
Got bored today so I went to kragens and got a timing light. Took a little less than 15mins to do everything, very easy! To my surprise, my stock setting was at 14 degrees. Is that normal?
Well after setting it to 18 degrees and taking the R out for a spin, I could definitely feel a nice pull compare to stock settings. I have the stock intake back on for the rainy season and w/ the 18degrees setting, the pull felt similar to when I had the AEM CAI.
What kind of hp/tq gains are expected with 18 degrees advance timing?
Edit: I found a dyno chart for a 1997 stock type-R from The Integra Dyno Center..
Are these numbers true for 2001 as well?
[Modified by ITYP3R, 7:28 AM 12/24/2001]
Old Dec 23, 2001 | 02:17 PM
Brett@SoloRacer.com's Avatar
Default Re: Just advanced my timing to 18 (ITYP3R)
Yep, mine was 14 too. I think thats the low end of the factory spec. 18 is the high end.
Old Dec 23, 2001 | 02:30 PM
Ibuprofen's Avatar
Default Re: Just advanced my timing to 18 (Fuzznuts)
I paid $79 and some change w/ tax. Has the **** adjustment on the gun. Pretty neat device. I plan to return it in a few days though.
Old Dec 23, 2001 | 03:43 PM
Peter Lim 1110's Avatar
If you advance your timing will it keep the setting until you re-adjust the timing to a different setting? My friend was telling me that with an OBDII, advancing your timing is useless because the ecu will just re-adjust it back to where it was after driving. Is this true?
Old Dec 23, 2001 | 03:45 PM
Rob :190:'s Avatar
Default Re: Just advanced my timing to 18 (Peter Lim 1110)
your friend is incorrect from what i've been told.
Old Dec 23, 2001 | 03:52 PM
magic hat #9's Avatar
Default Re: Just advanced my timing to 18 (Rob Maybach)
i don't know all the details (i paid the dyno man $30 to do it), but you have to jump the ecu to fool it (should be in the helms). my peak gain was 1whp and 1ft/lbs; nothing huge, but each little bit makes a difference, eh?
Old Dec 23, 2001 | 04:53 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Just advanced my timing to 18 (monkey_truckR)
I had mine advanced to 18 degrees and got 172whp and 125wtq. I also have a Comptech Icebox and filter but thats it.
jmal1919
Jun 1, 2005 12:39 PM
TypeRuz
Oct 31, 2003 08:50 PM
cnycivic
Jun 25, 2003 09:44 PM
Bbasso
Mar 3, 2002 06:16 PM
raw01
Jun 29, 2001 05:34 PM
