Ignition Timing?
Old Mar 3, 2002 | 10:22 AM
Bbasso's Avatar
Default Ignition Timing?
the stock timing is or should be what? next
what would be a safe amount to increase it to if still stock, i heard 18
is that true?
Thanks fo the help
Old Mar 3, 2002 | 10:27 AM
Black SVT's Avatar
Default Re: Ignition Timing? (Bbasso)
18
Old Mar 3, 2002 | 10:28 AM
Bbasso's Avatar
Default Re: Ignition Timing? (Dc2k-specR)
thanks
Old Mar 3, 2002 | 11:57 AM
kkim's Avatar
stock timing is 16d +/-2d, so 18d is still within the stock specs. I have mine set to 18d and have had no ill effects from doing so. low and midrange seems to be a bit stronger and gas mileage is supposed to improve, but that's a hard one to confirm. just make sure you use a timing light to set it.
Old Mar 3, 2002 | 03:11 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
the stock timing is or should be what? Thanks fo the help
correct, stock is 16 deg. +/- 2 degrees. just a little hint though, when i dynoed i made most power at 16 degrees. i tried 19,18,17 and 15, but it liked 16 the best.
Old Mar 3, 2002 | 06:16 PM
kkim's Avatar
Default Re: Ignition Timing? (rodney)
hmmm, that's intereseting. I'd like to see the dyno plots, if you have them. I only us the ol' butt dyno and advanced to 18 seems to yield the best feeling lower power. how did the torque readings differ with each reading?
emotionisdead
Dec 23, 2004 03:52 PM
hmongboyLS
May 13, 2004 11:36 PM
TypeRuz
Oct 31, 2003 08:50 PM
TypeR 1159
Apr 8, 2002 03:24 PM
Ladies Man
Jun 15, 2001 06:58 PM
