Disk brakes imperative??
Old Nov 5, 2004 | 09:17 AM
Death_to_Thieves's Avatar
Default Disk brakes imperative??
Im buying a 88 crx si and it has no rear disk brakes. I was given a great link on how to do the conversion from drums to disk but its alot harder than I thought it would be and requires more effort than I thought. Im am going to be swapping in a motor ( see sig) and wanted to know if you guys think that the rear drums are going to be good enough for stopping power. Are disc brakes absoloutley imperative in a crx with swap?? Are the drums good enough or do I have to do the brake conversion?
Old Nov 5, 2004 | 12:24 PM
Default Re: Disk brakes imperative?? (8000KReV)
ttt
Old Nov 5, 2004 | 12:40 PM
drdisco69's Avatar
Drums are fine, unless you road race every weekend.
Old Nov 5, 2004 | 12:43 PM
Sack Master's Avatar
Well your front brakes make up about 70% of your stopping power. So you really don't need them unless you plan on doing some sort of road racing. But disk brakes are much better all around. But its not required.
Old Nov 5, 2004 | 01:00 PM
01SSAP1's Avatar
Drums should be fine if you are not racing
Rear drums will actually have a larger braking surface then discs
Discs shed heat better though so they are more resistant to fade.
So in a racing situation where you are flogging the brakes constantly you want discs. On a road car drums suffice.
Old Nov 5, 2004 | 02:50 PM
Default Re: Disk brakes imperative?? (2KCivicSiR)
Ill be doing some racing, no road racing but Ill be drag racing occasionally. Im trying to get the CRX to run like high 13's all motor, maybe low 13's in the 1/4 with nitrous. Im in CT and the nearest 1/4 drag strip is Englishtown NJ so i wont be racing like every weekend, maybe like couple times every couple months. So you think Im good with the drums for this type of setup and racing? Thanks for everyone also for their previous replies I appreciate it as always
Old Nov 5, 2004 | 02:59 PM
drdisco69's Avatar
Lol, for one stop every 8 minutes, you'll be fine with drums.
Old Nov 5, 2004 | 03:13 PM
Default Re: Disk brakes imperative?? (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Lol, for one stop every 8 minutes, you'll be fine with drums.</TD></TR></TABLE>
thanks man
jxhxb
Oct 6, 2007 03:53 PM
1nicegsr
Honda Civic (2001 - 2005)
Jan 15, 2007 03:52 PM
Syndacate
88
Jun 19, 2006 11:33 AM
mandelo
Jun 15, 2004 12:08 PM
makaveli284
23
Mar 8, 2004 06:13 PM
