H-T SWAP GURU'S, I NEED YOUR HELP!
Old Nov 5, 2004 | 08:04 AM
BackSideSA's Avatar
Default H-T SWAP GURU'S, I NEED YOUR HELP!
I HAVE A 97 CX WITH 95 GSR MOTOR
MOTOR IS ALREADY HUNG IN CAR, HAD TO PURCHASE A 99-00 B SERIES REAR MOUNT (IS THAT RIGHT?)
PURCHASED OBD2A TO OBD1 WIRE CONVERSION HARNESS FROM BLOWN90HATCH (THANKS A LOT BRO!)
FROM WHAT I KNOW NOW I NEED TO CONVERT ALL THE WIRING ON THE MOTOR TO A 96-97 GSR WIRING LOOM. ALSO THE INJECTORS OR WHAT NOT.
WHAT WILL WORK SO I CAN GET THIS GOING? I SEARCHED UNDER SOME DIFFERENT KEYWORDS AND COULDNT GET ANY GOOD INFO. I KNOW THIS HAS BEEN DISCUSSED A MILLION TIMES ON THIS BOARD SO I AM SORRY FOR THE REPETITIVENESS. ALSO I HAVE CAPS LOCK ON SINCE I AM AT WORK...SORRY FOR THE SENSITIVE READERS OUT THERE!
Old Nov 5, 2004 | 08:07 AM
BackSideSA's Avatar
Default Re: H-T SWAP GURU'S, I NEED YOUR HELP! (BackSideSA)
WILL A 99 EX ENGINE WIRE LOOM WORK?
Old Nov 5, 2004 | 08:25 AM
BackSideSA's Avatar
BUMP
Old Nov 5, 2004 | 09:08 AM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BackSideSA &raquo;</TD></TR><TR><TD CLASS="quote">WILL A 99 EX ENGINE WIRE LOOM WORK?</TD></TR></TABLE>
First, please hit your caps lock button.
The 99 ex loom will not work. '99 is OBD2B while your '97 is OBD2A.
Reuse your stock cx harness.
You will need to switch the following to obd1 plugs: Injectors, distributor, and alternator.
Then you will need to run wires for the vtec solenoid, vtec oil pressure switch, knock sensor and intake air bypass.
Old Nov 5, 2004 | 09:35 AM
BackSideSA's Avatar
Default Re: H-T SWAP GURU'S, I NEED YOUR HELP! (Slopoke)
SORRY FOR THE CAPS (AT WORK AND WE HAVE CAPS "LOCKED" SO I CANT TURN THEM OFF)
THE STOCK CX HARNESS WAS NOT THERE SINCE I BOUGHT THE CAR WITHOUT MOTOR IN IT
Old Nov 5, 2004 | 10:32 AM
Slopoke's Avatar
Oh, I see.
Well, the easiest thing to do is to get a '96-'98 ex harness.
It is already wired for vtec, but you will still have to change the plugs and run the wires for the IAB. I'm not sure wether or not the obd2 ex civics had knock sensors or not. Maybe someone else can confirm that.
Old Nov 5, 2004 | 12:39 PM
BackSideSA's Avatar
WELL I WAS ABLE TO FIND A 96 EX ENGINE HARNESS. FOR AN AUTOMATIC THOUGH, I THINK I WILL HAVE A PLUG THAT WILL BE HANGING FOR THAT NOT IN USE.
THANKS FOR THE HELP Y0!
Old Nov 5, 2004 | 12:52 PM
chad's Avatar
Moderator
interesting
Old Nov 5, 2004 | 03:17 PM
BackSideSA's Avatar
Default Re: H-T SWAP GURU'S, I NEED YOUR HELP! (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">interesting</TD></TR></TABLE>
JUST WONDERING WHAT YOUR INPUT WAS? ANY ADVISE CAN BE A HELP RIGHT NOW......
Old Nov 5, 2004 | 03:22 PM
chad's Avatar
Moderator
JUST WONDERING WHAT YOUR INPUT WAS? ANY ADVISE CAN BE A HELP RIGHT NOW......</TD></TR></TABLE>
11
take it to someone who knows what they are doing
Old Nov 5, 2004 | 03:57 PM
BackSideSA's Avatar
IT IS AT MY LOCAL SPEED SHOP RIGHT NOW. THE ONLY THING WE HAVE BEEN HAVING PROBLEMS WITH WAS TRYING TO FIND A HARNESS SINCE I BOUGHT THE CAR WITHOUT A MOTOR. THEY DIDNT HAVE ANY LYING AROUND SO I HAVE BEEN LOOKING FOR SOMETHING I COULD USE OR SOMETHING THAT IS COMPATIBLE, WITHOUT HAVING TO CALL THEM A 1000 TIMES.
I GUESS I JUST TRYING TO GAIN MY OWN KNOWLEDGE SINCE I AM NOT PHYSICALLY DOING ANYTHING. I HAVE BEEN SEARCHING EVERYTHING AND HAVE CAME UP WITH A LOT OF INFO THAT I SHOULD HAVE DONE MY HOMEWORK ON BEFORE. I KNOW (SLAP TO THE BACK OF MY HEAD)
beerguy6903
22
Aug 31, 2009 07:47 PM
pootie.teng
Feb 12, 2004 01:16 AM
Team 4R
Dec 16, 2003 03:58 AM
jedi27sith
Apr 6, 2003 06:01 AM
HybridGSR
Jan 11, 2002 02:44 PM
