will an ek coupe exhaust manifold, mid/b-pipe and cat work on an ek hatch?
Old Nov 4, 2004 | 09:36 PM
EK k kay's Avatar
Default will an ek coupe exhaust manifold, mid/b-pipe and cat work on an ek hatch?
My dx hatch has the cat/exhaust mani combo in one piece and I was wondering if I could get the exhaust manifold from a coupe along with the cat and mid-pipe and put it on?
Old Nov 4, 2004 | 09:55 PM
chad's Avatar
Moderator
Default Re: will an ek coupe exhaust manifold, mid/b-pipe and cat work on an ek hatch? (chowmien)
it should fit....
get
header
cat
mid/b pipe....
rear section is longer on the coupe....but i believe everything else is the same
Old Nov 4, 2004 | 11:38 PM
yoshi_1r's Avatar
it should fit cuz it just connects to the cat and all..
Old Nov 4, 2004 | 11:48 PM
EK-Chris's Avatar
Default Re: (yoshi_1r)
I found out the hard way : Make sure they are the same motor. A Y8 exhaust manifold will physically fit on a Y7 (CX/DX) motor. BUT the oxygen sensor on a Y7 is on the lower portion -vs- (Y8) right on front of the maifold. I had the option to look for a Y7 Manifold OR lenghten the wires. Its up to you, hope this helps
Old Nov 6, 2004 | 11:18 PM
EK k kay's Avatar
Default Re: (EK-Chris)
I plan on using y8 exhaust manifold, y8 cat, and y8 mid pipe.
Old Nov 6, 2004 | 11:28 PM
E-brake or Handbrake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-Chris &raquo;</TD></TR><TR><TD CLASS="quote">I found out the hard way : Make sure they are the same motor. A Y8 exhaust manifold will physically fit on a Y7 (CX/DX) motor. BUT the oxygen sensor on a Y7 is on the lower portion -vs- (Y8) right on front of the maifold. I had the option to look for a Y7 Manifold OR lenghten the wires. Its up to you, hope this helps </TD></TR></TABLE>
Don't you mean the Y7 exhaust manifold has the o2 sensor right on the front VS the Y8 has it underneath? I could prove this because I own a d16y7 and my exhaust manny has an o2 sensor coming from the front sticking right next to the A/C fan. There is also another o2 sensor running right after the cat.
Old Nov 7, 2004 | 02:39 AM
EK-Chris's Avatar
Default Re: (Inconclusive)
Yeah, sorry..
Old Nov 7, 2004 | 11:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-Chris &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, sorry.. </TD></TR></TABLE>
No problemo We're all here to benefit from eachother's information.
94 IntegraLS
Jun 21, 2011 06:17 AM
Team_Insane
May 12, 2011 08:25 PM
jahasiel
Mar 24, 2007 02:49 PM
Gouki133
17
Feb 12, 2007 10:48 AM
jdmjunkieXL
May 1, 2006 10:53 PM
