VTEC
Old Nov 4, 2004 | 06:40 PM
SiR Inspired ED7's Avatar
Default VTEC
since i have no ecu (Vtec Won't Engage)
my cuz told to me to run vtec by running it with high lights or somehing like that while i get my ecu
someone explain to me what the hell he meant, or something
Modified by 93 Da 16a at 3:52 AM 11/5/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booja &raquo;</TD></TR><TR><TD CLASS="quote">
but if they arent and the vtec sol. is hooked up straight to a 12 volt source. does it matter about the other things still for it to work? ex:if i had no vss but i still hard wired vtec to a 12v volt source will it still work (at the right rpm range of course)? </TD></TR></TABLE>
Modified by 93 Da 16a at 3:59 AM 11/5/2004
Old Nov 4, 2004 | 06:50 PM
mmuller's Avatar
Mad Scientist
Default Re: VTEC (93 Da 16a)
what?
Old Nov 4, 2004 | 06:51 PM
Default Re: VTEC (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">what?</TD></TR></TABLE>
yea, that's what i'm saying...idk what the hell he meant...
Old Nov 4, 2004 | 07:02 PM
drdisco69's Avatar
If you have no ecu, the car won't run, so don't even worry about vtec.
If you have a non-vtec ecu and you're getting a vtec ecu, just don't use vtec. Life will suck, but you'll appreciate it that much more when you have it.
Old Nov 4, 2004 | 07:23 PM
HONDA_TYPE_R's Avatar
Default Re: VTEC (drdisco69)
I have heard that you can wire VTEC to a 12v power source that's always on when your car's on. Or, you can use a VTEC controller...not sure about either of the two, but I would listen to drdisco69. VTEC was VERY rewarding once I had it. It may be getting me in to trouble though.
Old Nov 4, 2004 | 07:24 PM
ok, thanks...
Old Nov 5, 2004 | 04:22 AM
drdisco69's Avatar
Default Re: VTEC (HONDA_TYPE_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">I have heard that you can wire VTEC to a 12v power source that's always on when your car's on.</TD></TR></TABLE>
You don't want vtec on all the time, trust me. I accidently set mine to 1800rpm one day, and that was one pissed off engine. Vtec at idle will probably stall the car.
Old Nov 5, 2004 | 10:56 AM
tgreaves's Avatar
I ran vtec at idle on my mini-me once(by accident) and it sounded like it had a nasty *** cam in it.. It also didnt have any power until the rpms started to get up there..
Old Nov 5, 2004 | 11:45 AM
drdisco69's Avatar
Default Re: VTEC (tgreaves W)
Then I'll add to my statement by saying that a DUAL cam will probably stall.
Old Nov 5, 2004 | 11:47 AM
tgreaves's Avatar
Probably.. But dont they have those vtec killer rockers that eliminate vtec or something like that.. They might need a special cam or maybe special tuning and a higher idle to function properly..
Old Nov 5, 2004 | 11:56 AM
drdisco69's Avatar
Yeah, for a full race deal like that, you can let it idle at like 2000rpm and not care.
Hell, F1 motors idle at 9000 rpm...
Old Nov 5, 2004 | 11:57 AM
tgreaves's Avatar
Damn.. Where do the f1 motors redline at?
Old Nov 5, 2004 | 12:05 PM
drdisco69's Avatar
Ferrari was revving to 18,900 this past year, Honda was at around 18,600 I think.
Old Nov 5, 2004 | 12:14 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Ferrari was revving to 18,900 this past year, Honda was at around 18,600 I think.</TD></TR></TABLE>
Hmm.. Thats pretty high.. Whats it sound like?
Old Nov 5, 2004 | 12:37 PM
Ricochet.'s Avatar
Image a motorcycle revving to 12k+ on the freeway, then imagine it even higher-pitched by 6k rpms..
Old Nov 5, 2004 | 12:50 PM
drdisco69's Avatar
Default Re: VTEC (Ricochet.)
I love hosting:
http://www.coe.uncc.edu/~mdkee...3.mp3
http://www.coe.uncc.edu/~mdkee...4.mp3
http://www.coe.uncc.edu/~mdkee...s.mp3
http://www.coe.uncc.edu/~mdkee...g.mp3
Old Nov 5, 2004 | 01:10 PM
Ricochet.'s Avatar
I just wacked off that those
Old Nov 5, 2004 | 01:19 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricochet. &raquo;</TD></TR><TR><TD CLASS="quote">Image a motorcycle revving to 12k+ on the freeway, then imagine it even higher-pitched by 6k rpms..</TD></TR></TABLE>
Im gonna build me one of those..
Old Nov 5, 2004 | 01:20 PM
drdisco69's Avatar
Stock GSXR 600 RR does 16,000 this year, I believe. 12,000 is old school.
Old Nov 8, 2004 | 09:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricochet. &raquo;</TD></TR><TR><TD CLASS="quote">I just wacked off that those</TD></TR></TABLE>
I'll second that. Ferrari OWNZZ!!!
Old Nov 8, 2004 | 10:00 AM
dfoxengr's Avatar
no mmuller meant what as in your grammer and sentence composition sucks. we can barely undderstand what you are trying to convey. did you pass freshman englisg in high school?
Old Nov 10, 2004 | 09:04 AM
JohnnyB70's Avatar
Default Re: VTEC (hybridvteceg)
MY guess was that he meant to hook it up to the high beam headlight switch. So when you wanted Vtec to kick it you would turn on ur high beams. Just a wild guess.
Old Nov 10, 2004 | 09:28 AM
JRciv's Avatar
Default Re: VTEC (JohnnyB70)
Mmmm... So you'd have to flip your lights on and off every time you shift during acceleration... Sounds like a good plan to me.
dohcgarage@714
Honda S2000
26
Nov 8, 2007 11:29 AM
CodyC142
13
Apr 13, 2006 09:34 AM
codyb13
Oct 19, 2005 06:21 PM
PearlBlueType-S
Aug 17, 2005 07:21 AM
kungura
Honda S2000
Jul 10, 2005 06:23 AM
