205/55/15 tire rubbing?
Old Dec 22, 2001 | 01:48 PM
TypeR 599's Avatar
Default 205/55/15 tire rubbing?
would that tire size on the stock rims rub something like the springs or something? i hear some noise and it sounds like rubbing. would it rub if the car was lowered about 3/4 of an inch?
[Modified by type R 599, 10:57 PM 12/22/2001]
Old Dec 22, 2001 | 02:05 PM
mugenr#1011's Avatar
Default Re: 205/55/15 tire rubbing? (type R 599)
it shouldnt..did you check to see if the noise could be something else? and does it do it only when you turn?
Old Dec 22, 2001 | 02:07 PM
TypeR 599's Avatar
Default Re: 205/55/15 tire rubbing? (mugenr#1011)
it only happens from turning. i checked some other stuff but couldn't find anything. all the engine mounts were on tight and everything. so i dont know..any sujestions?
Old Dec 22, 2001 | 02:22 PM
BlazinITR's Avatar
New User
My tires rub too with the 205/55 15 on OEM rims, but my ITR is also dropped 3/4 to 1 inch. It only happens when I make a turn with my wheels turned all the way till it stops. I also found out where it rubs from wear marks on the inner plastic panel of the tire well.
Old Dec 22, 2001 | 02:24 PM
TypeR 599's Avatar
Default Re: 205/55/15 tire rubbing? (Blazin ITR)
wow...so guess i is coming from my tires. thanks for the info. i'll check it out later.
Old Dec 22, 2001 | 06:27 PM
magic hat #9's Avatar
i have 205/55/15 dunlop 5000 tires on my R now. it's completely stock and rubs at close to full lock in both directions. i would think a lowered car would rub even worse.
Old Dec 22, 2001 | 08:43 PM
TypeR 599's Avatar
Default Re: 205/55/15 tire rubbing? (monkey_truckR)
damn. well aleast it isn't something too bad, i was thinking a motor mount came loose or something. yeah i see some wear on the inner part of the wheel well. will too much of this be really bad?
Old Dec 22, 2001 | 09:47 PM
ArcticFreeze's Avatar
New User
Why go 205/55? Stock is 195/55 and 205/50 is a better fit.
Old Dec 23, 2001 | 06:25 AM
Default Re: 205/55/15 tire rubbing? (ArcticFreeze)
tire rub is not really all that bad. you could conceivably put extra wear on your tire or suspension components (maybe even throw out your alignment), but i'm not worried about it. just don't turn the wheel so much it rubs, and get different sized tires next time.
i got the 205/55 because i was looking for a cheap set of tires for the winter. the 205/50 were $10/tire more expensive, and i figured the extra tire height would help to protect the wheels. it also helps to counteract the effect of 205/50 tires on the odo. i probably should have just gotten real winter tires, but these work quite well.
Old Dec 23, 2001 | 09:59 AM
CWITR's Avatar
My friend has a lowered GSR with that size tire and it does not rub.
Old Dec 23, 2001 | 10:49 AM
TypeR 599's Avatar
i think i should just get a different size tire next time. that sound gets really annoying. thanks guys
99dxb18c1turbo
Aug 3, 2010 12:17 PM
ninjadancer
11
Oct 15, 2009 03:18 PM
shibbywhitedude
Jun 24, 2008 05:01 PM
zither
Jun 22, 2002 08:14 AM
4doorH22
11
Oct 3, 2001 04:36 PM
