Difference between Cross drilled and slotted rotors
Old Dec 22, 2001 | 12:28 PM
lliew's Avatar
New User
Default Difference between Cross drilled and slotted rotors
Hey! As the title goes...what are the diff between cross drilled rotors and slotted rotors? Well...other than they look different I guess....
Thanks.
Old Dec 22, 2001 | 12:47 PM
Cow's Avatar
Cow
Default Re: Difference between Cross drilled and slotted rotors (lliew)
One has holes and one has slits.
j/k.. um.. there's not much difference, neither really does anything except increase pad wear and decrease braking performance, and I believe cross drilled are quite prone to cracking.
You're much better off just getting oversized blanks if you want new rotors. http://www.fastbrakes.com makes some awesome brake kits for Honda's
Old Dec 24, 2001 | 11:39 AM
lliew's Avatar
New User
Default Re: Difference between Cross drilled and slotted rotors (Cow)
I just heard that cross drilled are prone to cracking too. So you wouldn't go with slotted rotors huh?
Thanks for the reply.
Old Dec 24, 2001 | 12:20 PM
speedymon's Avatar
slotted rotor help the gases from the pads escape. But in todays pads people say they don't produce that much gas. Thats what i heard.
Old Dec 24, 2001 | 01:00 PM
DAYUIZ's Avatar
Default Re: Difference between Cross drilled and slotted rotors (speedymon)
Well there is the obvious difference between one having holes and the other having slots. Then there is the difference between performance.
The cross drilled are suppossed to eleminate brake fade that is caused by gasses that get trapped between the pads and rotor. However as previously stated, modern pads don't generate that much gas. In theroy they don't work as well because the material that is missing due to the holes, there is less surface area but honestly I don't feel that it makes that big of a difference if any. I have crossed drilled rotors on my car and the difference was quite notable. I have very little to no brake fad and they stay cooler longer.....and I drive moutain roads twice a day.
Slotted rotors are suppossedly better than cross drilled. The slots let gasses escape just like the cross drilled, but since there is more surface area, the thinking is that these will stop you quicker.....however I doubt it makes that much of a difference. The whole cracking thing with the cross drilled rotors is a joke. Only if you're being insane and just going off on your breaks will you somehow find a way to crack them.
Its really a matter of preference. Just pick what you think looks good.
-Steve
Old Dec 24, 2001 | 01:46 PM
Flux's Avatar
Default Re: Difference between Cross drilled and slotted rotors (DAYUIZ)
Or if you are driving at a track....
Old Dec 24, 2001 | 07:46 PM
Charles B.'s Avatar
Default Re: Difference between Cross drilled and slotted rotors (Teken)
Very helpful info. I'm about to order some slotted ones with some EBCs (green stuff).
Old Dec 24, 2001 | 08:01 PM
Tweakmeister's Avatar
Default Re: Difference between Cross drilled and slotted rotors (SuperDuperEG)
I used to believe in slotted rotors, but recently I've been hearing from people that they aren't any improvement over blanks.
Then I saw a Maclaren production video...
Well, the Maclaren F1 uses cross-drilled Brembo's. I'm a believer
Old Dec 25, 2001 | 06:06 AM
DAYUIZ's Avatar
Teken: It's not a joke... It's a reality of metal fatigue and stress risers... FACT !!!
Regards
Teken
_______
Ok....you got me there. What I meant by that statement is that people worry about cracking their rotors when 99% of them are really just going to be hard on them every now and then. The fact that they think their driving style is going to crack the rotors is a joke. Thats what I meant.
-Steve
scubacamper
Oct 23, 2016 06:13 PM
ComCool
Feb 24, 2005 07:34 AM
JHD_DA
Aug 12, 2004 06:40 AM
Ozluder
Jan 26, 2004 03:24 PM
shipsaeki
Apr 14, 2003 04:56 PM
