Transmission Oil, anyone tried Motul 10w40?
How exactly is that stuff marked? Engine oil & gear oil are listed against completely different viscosity scales.
Before Honda started 'making' their MTF, they called for 10w-30 engine oil. Then their MTF is basically the same viscosity with some EP additives.
Engine oil 10w-30 is about the same viscosity as gear oil 70w-80 or something like that. If that Motul is actually labeled as 10w-40 GEAR oil, that's a lot thinner.
Here's the Full Info:
-Motyl Gear
-Gearbox oil
-SAE 10W40 Technosynthese(semi-synthetic)
-Ester based formula
-API SG/SH - API GL-4
I have my suspiscions that this stuff is just rebadged 10w40 motorcycle oil(same idea because tranny is lubricated by engine oil)
Edit: I spoke with a guy from Motul, and this is supposedly the right one for Honda trannys.
-Motyl Gear
-Gearbox oil
API SG/SH is a gasoline-engine spec. That implies the 10w-40 is an engine-oil weight.
API GL-4 is a gear oil spec. That implies that it's gear-oil weight.
Maybe an oil can meet both SG/SH & GL-4 specs, but the weight has to be one or the other. Does it feel like engine oil or is it obviously too thin?
I drained the oil and compared it to the Motul. It feels about the same so I'm not worried.
The main reason I am putting different oil is because it gets -35 degrees celius where I live and I wanted something that will protect better on cold startups. Hope it helps.
thanks for the help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shane54 »</TD></TR><TR><TD CLASS="quote">I drained the oil and compared it to the Motul. It feels about the same so I'm not worried.
thanks for the help! </TD></TR></TABLE>
You would want something thinner for cold weather protection. Not thicker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si »</TD></TR><TR><TD CLASS="quote">
You would want something thinner for cold weather protection. Not thicker.</TD></TR></TABLE>
exactly
exactly
