Head gasket and head stud reuse???
im picking up a b18b engine with the head off and I plan on boosting it. I wanted to throw on a cometic high boost gasket but didnt no if I could reuse my stock studs or if that was even a good idea. ARP is an option but just wanted to no it it could be done without
let me no
thanx
let me no
thanx
How high of boost are you planning on running? "Boost" headgaskets are extra money that you don't need to spend - unless you are running higher pressure. Just make sure you get your motor tuned well, and a stock headgasket should be fine. It's detonation that blows headgaskets, not the boost.
regargless of what u throw at it, of course up to a point though, purchase a cometic boost application gasket and some nice ARP head studs and torque those babys down, btw not that i dont believe in cometic, but ARP's can be reused up to 20-25 times, as long as threadin isnt stripped, and even when it happens, you can order one bolt for a few bucks instead of around 100-120 for another whole set......also gasket runs around 100-120 i think
from my understanding the cometic gasket will lower the compression a little which would help with the longlivity of my stock b18. I had the head off and i was like what the hell. why not. So you guys think the stock head gasket with the arp head studs would do the job just fine???
b00stedbyFastrax
Sep 14, 2002 09:08 PM
