to build the bottom end for turbo, what would you need to upgrade and what are the specs?
Old Nov 2, 2004 | 06:01 PM
Mackenzie's Avatar
Default to build the bottom end for turbo, what would you need to upgrade and what are the specs?
the example engine could be a b16. what would have to upgrade to run good high boost? and the compression ratios of the pistons?
Old Nov 2, 2004 | 06:45 PM
Mackenzie's Avatar
nobody?
Old Nov 2, 2004 | 08:24 PM
mrspeaker's Avatar
Default Re: (Mackenzie)
Ductile Sleeves.
Between 8:5:1 - 9:5:1 pistons
Forged rods.
Knifeedge the crankshaft..(not needed,but if you have the money,, do it)
Zero balance the rotating Assembly..
Block Girdle
Different oil pump gear
All ARP bolts.
Do this if you plan on runnin a Big turbo with lots of boost and high HP
Otherwise its overkill
Old Nov 3, 2004 | 04:03 AM
Mackenzie's Avatar
Default Re: (Mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">
Otherwise its overkill</TD></TR></TABLE>
lots of boost and high hp daily right?
Tjabo
Mar 10, 2009 10:39 AM
JZs15
Feb 26, 2009 03:21 PM
Takumi Fujiwara
Oct 15, 2004 06:51 AM
