ECU - 43 Fuel supply system
Old Nov 2, 2004 | 01:43 PM
killer6993's Avatar
Default ECU - 43 Fuel supply system
Alright sorry about posting in a seperate topic...
Anyways I just swapped Head Gaskets and now I'm posting a 43. Light doesnt stay on, and only comes on when the car is driven for 15 minutes or so. There is a buzzing coming from the Throttle Body, and getting an up and down idle.
I dont think it's a Vacumm leak either, turned the idle up (a lot) and that didnt help with the change in rpm's.
Any ideas on where to look, what to check?
93 CX Hatch with good ol D15
Old Nov 2, 2004 | 02:40 PM
killer6993's Avatar
Default Re: ECU - 43 Fuel supply system (killer6993)
!!!BUMP!!!
Anyone, any ideas?
Old Nov 2, 2004 | 05:49 PM
killer6993's Avatar
TTT
Old Nov 2, 2004 | 06:24 PM
XxRoCkMaNxNEOxX's Avatar
fuel pump?
Old Nov 2, 2004 | 07:41 PM
killer6993's Avatar
Default Re: ECU - 43 Fuel supply system (XxRoCkMaNxNEOxX)
Fuel Pump is good. Lines are good. Pressure is there.
Fuel pump was tested in another car, no probs.
Old Nov 5, 2004 | 02:10 PM
killer6993's Avatar
Just did oil change, topped off all fluids. Used some carb cleaner on the Throttle body.
Now I can hear it a little cleaner. Sounds like a vacuum link but all the hoses are good.
Anyone have any ideas on where else to be looking?
Old Nov 5, 2004 | 02:16 PM
2lua's Avatar
does it make like a loud hump? check to coolant lines go to the iacv you might got them reverse, and make sure the o-ring/gasket is not cut.
code 43. check the gas cap, change the fuel filter if needed, how old is the o2 sensor? might need to change it too.
Old Nov 5, 2004 | 03:26 PM
Glen Tennis's Avatar
I have a code 43 too. Changed fuel filter but still comes on randomly. I have a EG w/ B20. Not trying to thread jack, I just have the same problem.
Old Nov 7, 2004 | 07:39 PM
killer6993's Avatar
Default Re: (Rockinfunzone)
Gas cap is good.
Would those lines being switched still allow me to drive alright? The car drives good just the idle is up and down and the loud buzzing.
The code hasnt come on in like 3-4 days now but car is still having the problems.
I'm checking the 02 sensor again, but I dont see how that would allow for the buzzing.
97 DelSol SI
Honda Civic (2001 - 2005)
16
May 19, 2018 10:19 AM
PURPLETERROR aka BIGMATT
May 21, 2006 09:03 AM
ransack
Oct 7, 2002 12:10 AM
IdotheSHOCKER
Jun 30, 2002 10:17 PM
