Removing Power Steering?
Old Nov 1, 2004 | 11:39 PM
turbotime's Avatar
Default Removing Power Steering?
Is it hard to remove power steering in my ej coupe? I know there are kits for other cars but i havent seen one for mine. Also are there any good write-ups on the process?
Thanks
Old Nov 2, 2004 | 04:51 AM
snatch's Avatar
Default Re: Removing Power Steering? (turbotime)
You can just take the belt off if you want to do the quick and easy way. If you want to go all out, remove the pump and everything too, then you can buy a manual steering rack from a car that didn't have power steering. Say a VX or CX civic.
Old Nov 2, 2004 | 05:43 AM
monicle's Avatar
heres my walkthrough on adding power steering but the stps are basically the same if you are planning to swap in a manual rack. http://repo.jackmoves.com/album119
Old Nov 2, 2004 | 08:52 AM
turbotime's Avatar
if im swapping in a b17 will my standard ex ps bolt up to it?
Old Nov 2, 2004 | 09:26 AM
jbs's Avatar
jbs
Default Re: (turbotime)
Nope. You'll need a b-series PS. If you wanna leave out the PS, you could loop you current PS system. You could piece the kit yourself and source parts out from your local hardware store.
Old Nov 2, 2004 | 10:45 AM
monicle's Avatar
yeah you will need to use the pump only from the b17 if you want to retain a working power steering
Old Nov 2, 2004 | 08:04 PM
The Flying Dutchmen's Avatar
Default Re: (monicle)
The Flying Dutchman says manual steering is sporty and makes you cool!!
Old Nov 2, 2004 | 08:38 PM
4DRmafia's Avatar
oh hell yes i rock the manual steering it feels better
Old Nov 3, 2004 | 09:07 PM
Default Re: (SkipMic2006)
Take the AC out while your at it!!
Boostn B20
Sep 17, 2008 03:58 PM
Dragginglass
Mar 27, 2008 02:36 PM
irollerblade
Nov 7, 2007 10:04 AM
fabworxs
Oct 11, 2004 01:07 PM
CmptchAV6
Aug 23, 2001 05:01 PM
