Winter oil
I read a great writeup on car storage for itr in the archives. It was said to do an oil change just before putting the car away. I usually use Mobil1 10w-30 (synthetic) as I'm sure many of u do during the summer. What winter oil would u guys use to store your car? The coldest it will get is about -25 C or so for you Americans I think that's around O F, not sure I'll check that. The car will be turned on once a month and allowed to idle as article says. What brand and type? Thx
I usually switch to 5w30 in the winter months, normally run 10w30 or 15w50 for trackwork...
Used to run Mobil One, but got tired of the consumption. Recently switched to valvoline full synthetic, and the car seem to be using less.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type_r_jon »</TD></TR><TR><TD CLASS="quote">The coldest it will get is about -25 C or so for you Americans I think that's around O F, not sure</TD></TR></TABLE>
-25 C = -13 F
-25 C = -13 F
I'm not sure if starting your car at -25 C would cause more damage than just letting it sit for the entire winter. How much is a heated 10 x 20 storage unit?
ya it'll keep the clicks down and the car pretty. as i've spent many dollars on it already and plan to drop a Vortech SC in during the winter. it works. but would u guys do an oil change when u take it out of storage as well?
