Honda S2000 Honda S2000
oil loss
Old May 18, 2006 | 08:53 AM
TL1000R's Avatar
Default oil loss
I'm wondering if anyone else has this going on with their S2K. I notice that my car uses about a qt of oil every 3kmi. I've searched all over the motor for leaks, there are no drops or leaks on my garage floor or the driveway. The only thing I can think of is that she's burning it, although I've never seen any smoke even on start up. Is this normal or should I have it checked out? Thanks in advance....
Old May 18, 2006 | 09:22 AM
papa5murf's Avatar
Default Re: oil loss (TL1000R)
if you drive your car moderately hard or hit vtec here and there.. it's normal...... hense the reason you should check your oil after every hard run..
Old May 18, 2006 | 09:24 AM
SilverDc2's Avatar
Default Re: oil loss (papa5murf)
what type of oil are you running?
Modified by SilverDc2-Ap1 at 10:46 AM 5/18/2006
Old May 18, 2006 | 09:45 AM
p nut's Avatar
Default Re: oil loss (SilverDc2-Ap1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2-Ap1 &raquo;</TD></TR><TR><TD CLASS="quote">what type of oil are you running?</TD></TR></TABLE>
When I run M1 syn, I notice it burns about 1/2 - 1 qt every oil change (3k miles). I have run Castrol before (not on the S, but ITR), and noticed it didn't lose any at all.
Old May 18, 2006 | 10:03 AM
TL1000R's Avatar
I'm currently running 10w30 royal purple. Should I run Castrol or something else?
Old May 18, 2006 | 10:13 AM
JDM knowledge's Avatar
i use to use Mobil1 Syn as well. I noticed that **** would burn off about 1/2 qt modereatly. I use the Mobil 10w-30 regular now (regular Honda oil) and its a little better.
<FONT COLOR="red">If you VTEC you must check!</FONT>
Old May 18, 2006 | 10:15 AM
TL1000R's Avatar
Default Re: oil loss (JDM knowledge)
Thank you all..... I definately feel better now.
Old May 18, 2006 | 11:07 AM
Mr. Projekt's Avatar
* B A N N E D *
Pull your intake, look inside your TB.
Old May 18, 2006 | 02:32 PM
mykcuz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R &raquo;</TD></TR><TR><TD CLASS="quote"> although I've never seen any smoke even on start up. Is this normal or should I have it checked out? Thanks in advance....</TD></TR></TABLE>
if you see smoke during start up you have problems... unless you spill it during an oil fill then it will burn off the hot parts it touches, other then that you would really need to pray for a warranty.
since they havent created a 100% efficient engine yet, youre gonna burn off some hot fluids.
Old May 18, 2006 | 03:40 PM
cesteban's Avatar
if u run the vtec all the time the oil will burn up.
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
wessieball
Jul 6, 2006 04:15 PM
stevescivic
Jul 26, 2005 02:20 AM
fullraceacura
Feb 1, 2005 07:24 PM
onyx00
Jul 13, 2003 07:06 AM
