question about hydraulic jacks
Old Dec 21, 2001 | 11:28 AM
mr tl's Avatar
Default question about hydraulic jacks
my car is 2.2tons
will a 2 ton jack be ok? i figured i'll only be raising the front of the car, which is much less than the overall weight. (68% front/32% rear)
or should i go for a 2 1/4 ton jack? (which is able to support the entire car)
thanks
Old Dec 21, 2001 | 12:05 PM
Perfectionist's Avatar
Default Re: question about hydraulic jacks (mr tl)
Lifting the vehicle is one thing. Getting under it in that state is another. NEVER rely on the jack to hold your car up. Get a pair of jack stands at least, and be safe!
Old Dec 21, 2001 | 12:10 PM
rainforest's Avatar
just to be safe go with the 2 1/4 ton jack all the 2.2 ton's of you car won't be on the jack
[Modified by rainforest, 9:11 PM 12/21/2001]
Old Dec 21, 2001 | 12:23 PM
gsrvx's Avatar
New User
Default Re: question about hydraulic jacks (rainforest)
In addition to the jackstands...put blocks behind/in front of the wheels. You can never be too safe.
-Rod
Old Dec 21, 2001 | 12:57 PM
mr tl's Avatar
yeah, im planning on jacking the front up (e brake on), blocking the rears, putting a stand on each side, then lowering it.
i just wasnt sure if i should go for the 2 or 2.25 ton jack. i figured i'll save $10 by getting the 2 ton
Old Dec 22, 2001 | 03:11 AM
mr tl's Avatar
its made by a canadian brand. works pretty good. thanks
Old Dec 22, 2001 | 03:14 AM
Roach2k's Avatar
New User
a 2 ton jack will be fine. when you jack up your car, you're not lifting the entire weight of the vehicle at that one jacking point. i agree with the above statements that you should get as many jackstands under your car. they're the only safety net keeping the car from falling on you.
tho my car isn't 4 tons, i have a 4 ton hydraulic service jack with 4 3-ton stands and 2 6-ton stands... you can never have too much safety
92civicx
Jan 7, 2008 07:15 PM
94 IntegraLS
Apr 18, 2007 07:16 PM
TurboEM1
Apr 17, 2005 07:18 PM
dclub01
Aug 18, 2003 04:21 AM
Zulu888
Aug 20, 2002 02:47 PM
