Do you guys know what degrees BTC should be for stock timing for 00 civic EX
Old Oct 30, 2004 | 01:57 PM
Jaydeep's Avatar
Default Do you guys know what degrees BTC should be for stock timing for 00 civic EX
Do you guys know what degrees BTC should be for stock timing for 00 civic EX? I think mine is off. How can I change it to stock?
Old Oct 30, 2004 | 02:03 PM
Inspector Gadget's Avatar
Default Re: Do you guys know what degrees BTC should be for stock timing for 00 civic EX (Jaydeep)
16 BTDC
Correct me if I am wrong.
Old Oct 30, 2004 | 08:18 PM
hatchi's Avatar
how much are you off. try rotating the dist
Old Oct 30, 2004 | 08:20 PM
97vtecex's Avatar
Default Re: Do you guys know what degrees BTC should be for stock timing for 00 civic EX (hatchi)
my 97 ex with a d16y8 is set at 12 degrees BTC
Old Oct 30, 2004 | 08:21 PM
BauleyCivic's Avatar
Risky Business
Default Re: Do you guys know what degrees BTC should be for stock timing for 00 civic EX (97vtecex)
16 is correct, run 18 if you are n/a for a little more in power.
You adust it by getting a timing light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97vtecex &raquo;</TD></TR><TR><TD CLASS="quote">my 97 ex with a d16y8 is set at 12 degrees BTC</TD></TR></TABLE>
Uh, thats not good. Should be around 16.
Old Oct 30, 2004 | 08:22 PM
97vtecex's Avatar
Default Re: Do you guys know what degrees BTC should be for stock timing for 00 civic EX (BauleyCivic)
Uh, thats not good. Should be around 16.[/QUOTE]
you sure?? cause my manual and chiltons says 12 but then again the two books disagree with eachother on stuff like compression ratio
Old Oct 30, 2004 | 08:34 PM
Risky Business
Helms manual buddy. Its common knowledge on honda's that stock timing is 16 btdc
Old Oct 30, 2004 | 08:37 PM
RYAN_SJ's Avatar
stock is 16 deg. +- 2 deg. You need a timing light to check it and adjust the distributor until the red light lines up with the arrow.
Old Oct 30, 2004 | 08:39 PM
97vtecex's Avatar
Default Re: Do you guys know what degrees BTC should be for stock timing for 00 civic EX (RYAN_SJ)
ok then i have a world of **** problem cause mine is at 12 deg. would that cause a low idle and lots of smoke??
Old Oct 30, 2004 | 08:53 PM
Risky Business
Don't know about smoke, but yes it would **** with your idle.
Old Oct 30, 2004 | 10:58 PM
FyReo3's Avatar
D16Y8 base timing is 12 BTDC.
Old Oct 31, 2004 | 08:53 AM
Jaydeep's Avatar
Default Re: (FyReo3)
Can someone conform if it is 12 BTDC or 16 BTDC?
thanks
Old Nov 1, 2004 | 07:22 AM
Jaydeep's Avatar
Default Re: (Jaydeep)
Mine is 16 BTDC. So is it right? or it should be 12 BTDC?
My car is running sluggish. If it is 12 BTDC then thats the reason. I don't have manual so can you guys confirm it?
Old Nov 1, 2004 | 07:34 AM
ek_b16's Avatar
advance the dizzy and it might help. Use to have idle problems with my z6 when i had it. I believed it was at 16btdc stock but i set it at 18btdc for a little retard power. It idles funny cause your bottom end is advance and your tdc is retarded plus your dizzy might be center. play with the dizzy
Old Nov 1, 2004 | 09:25 AM
Risky Business
Default Re: Do you guys know what degrees BTC should be for stock timing for 00 civic EX (ek_b16)
It's 16, I ran at 19 N/A now I run 8 boosted
hastingsr
Jun 3, 2020 04:39 PM
Nothing.Special
Jul 23, 2004 01:59 PM
Jerry
Jan 27, 2003 05:42 PM
Lynx
Aug 1, 2002 07:44 PM
94civicx
Mar 23, 2002 04:50 PM
