Do you guys know what degrees BTC should be for stock timing for 00 civic EX
Do you guys know what degrees BTC should be for stock timing for 00 civic EX? I think mine is off. How can I change it to stock?
Risky Business
Re: Do you guys know what degrees BTC should be for stock timing for 00 civic EX (97vtecex)
16 is correct, run 18 if you are n/a for a little more in power.
You adust it by getting a timing light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97vtecex »</TD></TR><TR><TD CLASS="quote">my 97 ex with a d16y8 is set at 12 degrees BTC</TD></TR></TABLE>
Uh, thats not good. Should be around 16.
Re: Do you guys know what degrees BTC should be for stock timing for 00 civic EX (BauleyCivic)
Uh, thats not good. Should be around 16.[/QUOTE]
you sure?? cause my manual and chiltons says 12 but then again the two books disagree with eachother on stuff like compression ratio
Risky Business
Helms manual buddy. Its common knowledge on honda's that stock timing is 16 btdc
stock is 16 deg. +- 2 deg. You need a timing light to check it and adjust the distributor until the red light lines up with the arrow.
Re: Do you guys know what degrees BTC should be for stock timing for 00 civic EX (RYAN_SJ)
ok then i have a world of **** problem cause mine is at 12 deg. would that cause a low idle and lots of smoke??
Re: (Jaydeep)
Mine is 16 BTDC. So is it right? or it should be 12 BTDC?
My car is running sluggish. If it is 12 BTDC then thats the reason. I don't have manual so can you guys confirm it?
advance the dizzy and it might help. Use to have idle problems with my z6 when i had it. I believed it was at 16btdc stock but i set it at 18btdc for a little retard power. It idles funny cause your bottom end is advance and your tdc is retarded plus your dizzy might be center. play with the dizzy
Nothing.Special
07-23-2004 01:59 PM
