help on a d16z6 build
ok i have a d16z6 that blew a head gasket so i am going to tear it down and re-build it , but i would like to add the d16a6 pistons and rods to it instead of the stock z6 one's because that fact of the better bottom end on the a6. now if i can use the a6 pistions and rods should the rings be gapped for the z6 block or the a6 pistions
now i have done ALOT of searching before i wrote this post so please don't tell me to search
on here and other outside sources like d-series.org, none of them didn't really answer my question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hellshock2182 »</TD></TR><TR><TD CLASS="quote">try searching for the stroke length and bore of the a6's and find out if they are the same.
bore and stroke is identical. Only difference is piston dome displacement being more on the PM6's= higher comp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kysard »</TD></TR><TR><TD CLASS="quote">I think those pistones bring the C.R. over 12 with the z6 head</TD></TR></TABLE>
no way. Running P29's will put you over 12:1.
I am rumming PM6 pistons and rods in my D16Z6 and am untuned running 92 octane and 14* base timing and have no problems...deffinately need to tune it sometime tho- been putting it off for almost a year
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
how does that motor pull on the street?any dyno #'s/track times?
to the thread starter, yea the bore is all 75mm, so im going to venture that the gap should be to the pm6 pistons(if it doesnt turn out to be the same)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">
to the thread starter, yea the bore is all 75mm, so im going to venture that the gap should be to the pm6 pistons(if it doesnt turn out to be the same)</TD></TR></TABLE>
no numbers yet. Waiting on a Skunk 2 cam, and then I might jump on the dyno. I have it paired with my stock tranny with a 4.9 FD...and it's a very nice setup. This build was actually done spur of the moment after a spun rod bearing in this block with stock internals. I need an engine running fast for cheap...so I took rods/pistons out of an A6, slapped my old rings on those to use in the Z6 block, and have been running it ever since. I've actually had it since May, and put on at least 12k miles. Let a friend drive it and didn't pop the hood...told him I did something different and he was to guess, and he thought I put a B16 in there
thanks again for the info that helped me and answered my question just nicely, keep it up if there are any other pieces of info i would love to read it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrehagencivic »</TD></TR><TR><TD CLASS="quote">thanks again for the info that helped me and answered my question just nicely, keep it up if there are any other pieces of info i would love to read it
I can talk to you for days about D series man. And if you can, just run a stock D16A6 block with a Z6 head. Same characteristics as running a Z6 block with A6 pistons, but you will have steel mains with the A6 block- only D series with steel mains. email me if you wanna talk...
</TD></TR></TABLE>I can talk to you for days about D series man. And if you can, just run a stock D16A6 block with a Z6 head. Same characteristics as running a Z6 block with A6 pistons, but you will have steel mains with the A6 block- only D series with steel mains. email me if you wanna talk...
haha good **** man. im more than likely gonna put together a z6head/y5 block/a6pistons setup with my y5 when i pull it for an ls/turbo in a lil while. is there a particular reason you went with the skunk2 instead of the zex cam for your build? if you have some extra time, hit me back an email. if not good luck with the rest of the build and the dyno
</TD></TR></TABLE>haha good **** man. im more than likely gonna put together a z6head/y5 block/a6pistons setup with my y5 when i pull it for an ls/turbo in a lil while. is there a particular reason you went with the skunk2 instead of the zex cam for your build? if you have some extra time, hit me back an email. if not good luck with the rest of the build and the dyno
I can talk to you for days about D series man. And if you can, just run a stock D16A6 block with a Z6 head. Same characteristics as running a Z6 block with A6 pistons, but you will have steel mains with the A6 block- only D series with steel mains. email me if you wanna talk...</TD></TR></TABLE>
i will definity do that a buddy of mine (h-t member, ef-sihatch) and i are doing some build ups on our d-series' during the next couple of months
this might give you a little more help....but go ahead and click the first link in my sig. Pretty informative post on the D-series
kyorishin
Mar 22, 2006 12:07 PM
civicdust
Jan 14, 2005 04:24 AM
ef-sihatch
Nov 8, 2004 12:58 AM
daniboy4nspd
May 24, 2003 11:00 AM
