B16A 92-95 (SiR-II) into a eg please help me
i own a 94 hatch back.. i went to hmotorsonoline.com and they will sell me a B16A 92-95 (SiR-II) for 2250 here is what it comes with:Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
my question is .. will i be able to use the stock motor mounts that come wit the motor.. since the sirII comes in my car in japan.. or do i have to get hasport ones... also can i use the axles that come with the motor or do i have to get the custum ones from hasport for that too... are there any other parts i will need for the swap.. becuase ifcant use ne of these things then im not gonna buy the complete change over kit ill buy just the motor tranny and ecu for 1700.. please help me.. im lost!
- ECU (P30)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
yeah, the axles and motor mounts will work, however you dont know what kind of shape the motor mounts are in. so if you have the money upgrading to the hasports wouldnt be a bad idea. i have to buy hasports for my b16 swap cuz my motor moves back and forth really bad in the engine bay.
Youll be fine with the hmotors swap. I just bought one from them to swap into my 95 ex. The mounts worked fine and the axels worked fine. The only extra things i had to purchase was a Distributor rotor and a tranny side mount. Thats it. The motor was mint and fired right up. No worries, steve is the man and if something comes broken they'll replace it for free.
We just installed my buddies SIR2 from HMO a couple weeks ago....Ive NEVER seen an older motor so clean..were talkin pristine condition...Its also one hell of a strong runner also.
to HMO
to HMO
Got mine from them also, b16 sir II..it's in with hasports motor mounts. Just had a few slight problems with crazy idle since i got it ported out. Anyone know where the map sensor goes on to in the sirII? It's not on the throttle body....i don't see anything for it. Let me know asap i gotta get this fixxed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahatch741 »</TD></TR><TR><TD CLASS="quote">so after i buy the complete change over kit i wont need 2 buy ne thing else right....? or will i ?......</TD></TR></TABLE>
on the site it mentions that the start up warantee isn't valid unless you replace plugs, wires, timing belt, water pump, etc. so you probably should buy these things too.
but anyways, i got my c1 swap from there and it was extremely clean and started up right away.
to hmo.
to hmo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TriniTech »</TD></TR><TR><TD CLASS="quote">map sensor mounts on firewall</TD></TR></TABLE>
anyone have a picture? i really need some help..unless it's my damn IACV..type r one goes for 200!!!!!! too costly
greeneg1213
16
Jul 16, 2008 01:52 AM
Seto-Initial-B
Jul 26, 2006 10:31 AM
smokerz212
18
Apr 28, 2006 09:52 PM
The Alchemist...
May 2, 2005 03:49 PM
