EG B16 swap shopping list
Guest
Posts: n/a
Sorry if this has been covered - I looked though the FAQ and searched.
I have a 92 cx hatch and I would like to swap a B16 in - what other parts will I need in order to have everything on hand?
Thanks
B16A 92-95 (SiR-II) Complete Change Over
Price: $ 2250.00 Plus shipping and handling
Availability: In stock and ready to go
- Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
+ Aftermarket mounts
+ Header
+ Exhaust
Thanks
- Motor
- ECU (P30)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
+ Header
+ Exhaust
Guest
Posts: n/a
Re: EG B16 swap shopping list (slowdx9585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 »</TD></TR><TR><TD CLASS="quote">nothing </TD></TR></TABLE>
What about the small stuff that I would need get from autozone? Is there anything else I should replace while the swap is getting done?
you'll need fluids.....oil, coolant, I would check the transmission fluids. Also while the motor is out of the car I would change the timing belt, water pump, all that typical maintinece stuff. Good luck with swap
Re: EG B16 swap shopping list (w-a-o)
intake, water pump, timing belt, spark plugs, plug wires, dizzy cap + rotor, extra wire, soldering gun (to do wiring the right way), oil, tranny fluid, brake fluid, and an extra $100-150 for all the small extras that add up while you are working.
get some wires fore xtending some wires and runing tehm to teh ECU. if the ECU doesnt have the plugs cut and were unplugged u will need about 4-6 OBD1 pins to pin the wires into the ECU. other than that, maybe a rad hose.
Re: EG B16 swap shopping list (CRXified)
bump this up, I'm about to start the same swap that just came in from hmo. Just gotta buy a clutch pipe line that was cut and some hoses. Taking A/C and power steering out, ****'s just taking up space . will the linkage that came with the swap fit and will the rear engine mount fit too?
Re: EG B16 swap shopping list (roydogg)
i just did this swap int omy 94 cx
use your cx harness if the motor is jdm everything will be on the other side
u can also use your cx exhaust if you cant afford one right now(which what im doing right now)
stuff that is required:
motor oil
coolant
dot3(if u dont use your old clutch slaves)
tranny oil
oil filter
spark plug
radiator hose lower and upper
intake(if your intake tube was cut like my)
optional stuff that is well recommended:
brand new clutch kit(my came with a bad clutch fucked up my flywheel bolts from the clutch springs)
timing belt kit
del sol vtec throttle cable
if you get the motor from hmotors for the b16a sir2 complete swap
everything comes with it for a 92-95 civic hatch or delsol i believe
but for sure for a hatchback since i did one
also for the clutch line
my didnt come cut if it was cut use your old one works fine
Modified by komat at 8:03 PM 5/2/2005
motor oil
coolant
tranny oil
oil filter
spark plug
timing belt kit
