Timing or fueling?
Old Oct 29, 2004 | 12:45 PM
tianporn's Avatar
Default Timing or fueling?
Car is JDM EG9 Ferio with JDM B16a with Y21 hydro gearbox non LSD. Still has AC, PS.
Mods include:
Intake
4-2-1 headers with 2.25" mandrel bent exhaust with N1 muffler.
Enlarged T/B
Ported and polished head.
2 layer head gasket.
VAFC with stock settings.
Short shifter.
Im running about 10.7:1 compression and I run the equivalent of 91 octane for you guys in the states.
Here is my problem. I put the car in first and hit the gas and the car feels very unresponsive and slugs. It feels bogged down till the rpms rise up then it takes off. Then when I shift to second it does the same thing. sluggish then back to normal. I think its timing problem or do you think it could be due to fueling problems? Rich or lean?
As i said before, up in the high RPM's and in VTEC the car runs sweet. In it's current state i have run a 15.578 @ 90.12 MPH 1/4 mile. This is with a 2.496 second 60ft time due to slippery conditions and street tires. 1/8th mile is 10.154 @ 71.35 MPH car is running street trim with only spare tire and tools taken out.
Thanks
Old Oct 29, 2004 | 01:15 PM
blackmagicCRX's Avatar
Default Re: Timing or fueling? (tianporn)
mine does the same thing and I know that I am running rich. I just can't figure out why!
Old Oct 29, 2004 | 08:50 PM
tianporn's Avatar
Default Re: Timing or fueling? (blackmagicCRX)
Yeah i have a feeling that it's running rich as it backfires a bit under decelleration. But what I don't get is when my car is running at WOT i can hear a bit of pinging at around 4000rpm. This is confusing me because if im running rich, it is less likely to detonate right? And im suspecting the timing is a little too much retarded so I dont know why im getting detonation. Im using the highest grade octane fuel in New Zealand which is 98 octane (although i heard that is the equivalent of 91 octane in the USA).
Best bet is to throw the car on the dyno to check out my A/F ratios.
Any suggestions?
Old Oct 31, 2004 | 01:52 AM
tianporn's Avatar
Bumpage
Old Oct 31, 2004 | 01:33 PM
smart monkey's Avatar
I would check timing and also check fuel pressure. also check all your tune up parts to make sure they are not old or worn out
Old Oct 31, 2004 | 10:30 PM
tianporn's Avatar
Default Re: Timing or fueling? (smart monkey)
How would I check fuel pressure? Would I need to buy a fuel pressure gauge?
Old Oct 31, 2004 | 10:46 PM
Katman's Avatar
are you running a reprogrammed ecu at all?
getting any check engine lights?
perhaps your VAFC isn't setup correctly, which is tripping out the MAP sensor and the cause of your acceleration hesitation problem..
change your cams recently? perhaps you messed up when putting the timing belt back on at TDC and your off a tooth......which would cause the car to run boggy/rich/and hesitate on acceleration...
just some suggestions..
Old Nov 1, 2004 | 01:36 AM
tianporn's Avatar
Default Re: Timing or fueling? (K@man)
Nope stock P30 with VAFC on stock settings.
No cams . Definately not a tooth off as i can still run mid 15 second quarters. Just that its a bit sluggish down low.
VAFC is reading the revs and the throttle fine.
Old Nov 1, 2004 | 08:10 AM
derekcarr's Avatar
Confirm your timing with a timing light (easy), if that is bang on and you still have the same problem then go out and get a fuel pressure gague and check that. You are into the basics of how the motor runs. You could have a spark (timing), fuel, or air problem. Just take your time and do things step by step.
Derek
Old Nov 1, 2004 | 08:55 AM
Katman's Avatar
..hmm..
perhaps yer just experiencing how b16's have no low end torque then...which is normal! haha..
Old Nov 1, 2004 | 10:29 AM
skunk2finatic's Avatar
I had the same problem. Mine would backfire every now and then, "expecially when coming off throttle back into neutral". I was messin around with my ignition components, IE: cap, rotor, plugs, wires, coil.... My rotor was messed up, and I tested my coil and it came out below the values suggested in my haynes manual. I changed that out and it ran like ****! Well, duh! I probally messed up my firing order. So changed it and it ran badass.
if your misfiring, it's because your either not burning the fuel, or aren't getting the fuel to burn. Check ignition components, do a fuel pressure test "unless you have a gauge". and check to see for vacuum leaks.
Old Nov 1, 2004 | 12:03 PM
tianporn's Avatar
Default Re: Timing or fueling? (skunk2finatic)
Nah its definately not missing. I'm pretty confident its the a/f ratio or the timing. Maybe i need to change my fuel filter. I've driven my friends EK4 with a B16a with I/H/E and the low end is quite responsive and feels quite "nippy" while i can describe my low end to be quite "dull"
Supahr_Ed
Sep 13, 2005 01:57 PM
tianporn
28
Apr 18, 2005 12:37 AM
tianporn
Mar 25, 2005 09:02 PM
tianporn
14
Oct 31, 2004 02:19 AM
cornholioEK
May 21, 2003 07:22 AM
