HELP ME changed about everything Im still getting high TEMP and overheating!!!!
Old Oct 28, 2004 | 07:41 PM
Skank_aSS_Dara's Avatar
Default HELP ME changed about everything Im still getting high TEMP and overheating!!!!
man stop posting im done with the problem i got it fixed
Modified by DaRa_Da_SkAnK at 6:07 PM 11/2/2004
Old Oct 28, 2004 | 08:48 PM
ekgcool's Avatar
Default Re: HELP ME changed about everything Im still getting high TEMP and overheating!!!! (DaRa_Da_SkAnK)
I would condemn the radiator cap. The Spoon one may be bad. Go to Auto Zone and buy a cap for 10 bucks and try again. If still the same, I would guess either a weak water pump, or damaged block
Old Oct 29, 2004 | 05:19 AM
JimBlake's Avatar
Default Re: HELP ME changed about everything Im still getting high TEMP and overheating!!!! (tekracer)
... or maybe a bad temperature gauge.
Old Oct 29, 2004 | 05:25 AM
dcsportsciv's Avatar
do you have a frontmount intercooler in the way. the reason i ask is i have one on my civic and theres not enough airflow to cool the engine while your driving. im having the same problem but i figured out how to keep my car cool by not giving it much gas. on hondas if you let off the throttle and gear down, that cools your engine also, thats what ive been doing. and keeping my fan on also. Hope this helps. let me know
Old Oct 29, 2004 | 05:42 AM
loud_whispers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaRa_Da_SkAnK &raquo;</TD></TR><TR><TD CLASS="quote">Im down to the point where im really pissed off now
i changed headgasket, waterpump, thermostat, i have a koyo aluminum radiator spoon radiator cap, slim fan which is automatically on when i start my engine
but my temperture still goes up when i drive and its overheating somebody please tell me what is going on with this!!!!
no signs of leakage besides the resivour bottle it constantly overflows!!!! please help me
-dara</TD></TR></TABLE>
Did you change the hoses?
some small cracks in hoses you will not see..
get a pressure guage kit and blast the whole cooling system.
Coolant will spew from where the leak is..if there is one..
if not..
you have a shitty aftermarket part.
Old Oct 29, 2004 | 05:52 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaRa_Da_SkAnK &raquo;</TD></TR><TR><TD CLASS="quote">no signs of leakage besides the resivour bottle it constantly overflows!!!!</TD></TR></TABLE>When the reservoir overflows, is there air in the radiator?
The radiator cap lets water go into the reservoir when hot. As the system cools down it's supposed to suck that water back in. Something's letting it suck air instead?
Old Oct 29, 2004 | 07:06 AM
Default Re: HELP ME changed about everything Im still getting high TEMP and overheating!!!! (JimBlake)
air pocket in the system.
probably what it is..
drain the coolant and re-flush it again..
Old Oct 29, 2004 | 05:58 PM
murtnabila's Avatar
Default Re: HELP ME changed about everything Im still getting high TEMP and overheating!!!! (loud_whispers)
have you bled the system to get the air out? Did you install the thermostat correctly?
Old Nov 2, 2004 | 12:40 PM
egdriver057's Avatar
WHY DID YOU CHANGED THE HEAD GASKET TO BEGIN W/. IS IT JUST CAUSED OF THE OVERHEATING? IF IT WAS, THEN HOW HOT DID IT GET BEFORE YOU DECIDED TO CHANGED THE HEAD GASKET? ALSO DID TOU CHECK TO SEE IF YOUR BLOCK AND CYLINDER HEAD WAS STRAIGHT AND NOT WARPED? JUST Q's THAT MIGHT BE ABLE TO HELP YOU.
Old Nov 2, 2004 | 01:00 PM
Default Re: HELP ME changed about everything Im still getting high TEMP and overheating!!!! (egdriver057)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egdriver057 &raquo;</TD></TR><TR><TD CLASS="quote">WHY DID YOU CHANGED THE HEAD GASKET TO BEGIN W/. IS IT JUST CAUSED OF THE OVERHEATING? IF IT WAS, THEN HOW HOT DID IT GET BEFORE YOU DECIDED TO CHANGED THE HEAD GASKET? ALSO DID TOU CHECK TO SEE IF YOUR BLOCK AND CYLINDER HEAD WAS STRAIGHT AND NOT WARPED? JUST Q's THAT MIGHT BE ABLE TO HELP YOU. </TD></TR></TABLE>
wow wise guy why did you bring a post back from like awhile back and HIT YOUR ****** CAPSLOCK OFF.
my motor is a 92 and has miles on it where its time to do a maintence on it because i dont want it to bust out of nowhere just sit back and watch and read dont post moron
you act like your getting 6.75 an hour and getting mad at the whole world and ****
Old Nov 2, 2004 | 01:08 PM
murtnabila's Avatar
you act like your getting 6.75 an hour and getting mad at the whole world and **** </TD></TR></TABLE>
wth is this all about? Sounds like he was trying to help...why you flaming him? Am I missing something?
Old Nov 2, 2004 | 05:13 PM
Namikuz's Avatar
How long have you had the non stock fan. and is it spinning the correct direction?
I made that mistake once. Once I realised the fan was the problem....no problem!
I swaped polarity on the fan and it stopped o/heating when I drove it.
Old Nov 3, 2004 | 09:47 AM
Default Re: HELP ME changed about everything Im still getting high TEMP and overheating!!!! (Namikuz)
<FONT SIZE="10"><FONT COLOR="red">stop FAWKING POSTING to this dead thread its done deal with dammit!!!!!</FONT></FONT>
Old Nov 3, 2004 | 05:16 PM
hey man relax, maybe other poeple will have the problem in the future and will see this thread and see all the comments that were given, its better to have more comments then non at all.
Touge Tuning
Jun 27, 2006 06:17 PM
89sicivic
Jun 8, 2006 09:10 AM
Ebony and Ivory
Jun 23, 2005 02:06 PM
xXx Justin xXx
21
Mar 19, 2004 05:26 PM
92SiTurbo
May 30, 2002 05:54 PM
