Installing VTEC valve springs
Old Dec 20, 2001 | 11:32 AM
HX_Guy's Avatar
Default Installing VTEC valve springs
I know how to do the actual installtion part...but I have a question.
I ordered Integra Type R outer springs and Portflow inners. I received the Portflow ones just now and from the looks of it, they are all teh same...so Im assuming it doesnt matter which goes on the intake and the exhaust?
How about the ITR outer springs? Is there a intake and exhaust spring...or are they all the same?
And finally, do I need to check the installed height? Mike K said he never checks it and has had no problems. How would I go about checking if I do want to do this step?
Old Dec 20, 2001 | 11:45 AM
sgT's Avatar
sgT
Default Re: Installing VTEC valve springs (HX_Guy)
yes intake and exhaust are different.
The intake springs should have yellow paint on them
Old Dec 20, 2001 | 11:47 AM
HX_Guy's Avatar
Default Re: Installing VTEC valve springs (sgT)
But the inner springs are all the same?
Old Dec 20, 2001 | 12:01 PM
Mike K's Avatar
When using Portflow inner springs and ITR outer springs, installed height is right on. I've never seen any problems with it.
Install all springs with the yellow paint facing up.. and the Portflows in with the more coils facing down.
Old Dec 20, 2001 | 12:13 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: Installing VTEC valve springs (Mike K)
uhhh doh... when i put in my portflow inners they look about the same to me. i guess some of mine might be upside down. hmm can't remember exactly. shucks.
Old Dec 20, 2001 | 12:23 PM
HX_Guy's Avatar
Default Re: Installing VTEC valve springs (frank@b16a.com)
Hmm..Im sitting here staring at the Portflow inners and I really dont see a differance between one end and the other...looks the same to me.
Old Dec 20, 2001 | 12:27 PM
austrian type-R's Avatar
Yeah! I would be worried when I had installed them upsidedown. The coils gets slightly together on one side of the spring. Look carefuly.
I had luck when we did the valve springs swap. We figured after the 1st spring out, that there is a different in the coils. Lucky we saw this!
I don´t know if it does matter when you put the spring 180 degrees wrong in. But for some reason they made the coils so. Damn! you must lift the head again!
[Modified by austrian ITR, 10:29 PM 12/20/2001]
Old Dec 20, 2001 | 12:29 PM
BowSeR's Avatar
New User
yeah i have the inners also and they look the same to me. but i hear this set up is a bit better than the JUN set up
Old Dec 20, 2001 | 12:38 PM
HX_Guy's Avatar
Default Re: Installing VTEC valve springs (BowSeR)
Alright...just got off the phone with Portflow.
They said their inner valve springs are non-progressive...so there is no top or bottom to them
Also for the ITR outers, he said to use all yellows with the paint up liek Mike said...and sicne they are all yellows, there is no differance between the intake and exhaust springs.
Old Dec 20, 2001 | 01:44 PM
Banned
coo. 'cause i remember i stared at them for a while and they seem the same at both ends...
Dxs
Jun 15, 2008 07:14 PM
jdmb18c
Apr 2, 2005 12:29 AM
bxsi
Dec 27, 2004 07:44 AM
McFly
Feb 12, 2003 08:27 PM
