Yeah, another PS removal post
Old Oct 27, 2004 | 01:42 PM
yeegsr's Avatar
Default Yeah, another PS removal post
i did archieved search and unarcheived search ...and got one or two posts but the informations were so messy and not useful
im running civic 95 with 97gsr
anyway what are the proper ways to remove P/S and able to maintain a good idling? sensor related...rack
anyone know any website...or know how to remove PS please help me out....i'm looking at helm's manual but it would be better if you guys hlep me out more
thanxk guys
Old Oct 27, 2004 | 03:17 PM
dustrag's Avatar
i would tell you to buy a cx manual steering rack
then i will tell you to go talk to the guys in the eg forum!
Old Oct 27, 2004 | 04:00 PM
96integraLS's Avatar
Default Re: (dustrag)
just unbolt the ****. y do u people always need directions. unbolt it and u can loop it back with the existing tubing on the back of the firewall. if u cant figure out how take off bolts dont bother doing it
Old Oct 27, 2004 | 04:38 PM
BolivianDc2's Avatar
Default Re: (96integraLS)
there are two spouts sticking out of the rack, take off the rubber lines and and loop them. That is the most simple way, here are some threads with more info than you probably need to get to get the job done.
https://honda-tech.com/zerothread?id=46120
https://honda-tech.com/zerothread?id=563724
https://honda-tech.com/zerothread?id=184202
Old Oct 27, 2004 | 04:46 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96integraLS &raquo;</TD></TR><TR><TD CLASS="quote">just unbolt the ****. y do u people always need directions. unbolt it and u can loop it back with the existing tubing on the back of the firewall. if u cant figure out how take off bolts dont bother doing it</TD></TR></TABLE>
unbolting is not a problem....what about the racking or ilding problems due to unproper removal...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 &raquo;</TD></TR><TR><TD CLASS="quote">there are two spouts sticking out of the rack, take off the rubber lines and and loop them. That is the most simple way, here are some threads with more info than you probably need to get to get the job done.
https://honda-tech.com/zerothread?id=184202</TD></TR></TABLE>
yeah ill do a read upl on those posts...thanx guys....any more info for me?
Old Oct 28, 2004 | 11:51 AM
dustrag's Avatar
you have a 95 civic buy a civic manual powersteering rack that way you will have no problems w/ an unproper removal.. think of it that way
Old Oct 28, 2004 | 01:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustrag &raquo;</TD></TR><TR><TD CLASS="quote">you have a 95 civic buy a civic manual powersteering rack that way you will have no problems w/ an unproper removal.. think of it that way</TD></TR></TABLE>
yea but the steering ratio sucks. I drive a 92cx and a 96GSR regularly, the amount you need to turn the civic wheel is really noticable compared to the GSR rack.
Old Oct 28, 2004 | 02:10 PM
dustrag's Avatar
CIVIC / INTEGRA
NOT TOTALLY THE SAME THING NOW..
Old Oct 28, 2004 | 05:42 PM
yeegsr's Avatar
i need to know about the hose from the pump....what do i do with that....
Old Oct 28, 2004 | 05:58 PM
yeegsr's Avatar
Default Re: (yeegsr)
the hose from the pump to oil pressure switch..what do i do with it or where to lope it to...anyone please..
Old Oct 28, 2004 | 06:53 PM
Teknic73's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustrag &raquo;</TD></TR><TR><TD CLASS="quote">i would tell you to buy a cx manual steering rack
then i will tell you to go talk to the guys in the eg forum!</TD></TR></TABLE>
don't get a cx rack the throw is longer, unless if you plan on drag racing it won't matter to you.
loop your line and you'll be fine
Old Oct 28, 2004 | 09:20 PM
yeegsr's Avatar
Default Re: (Viorent Grip! 73)
how do i loop it? and where at
Old Oct 28, 2004 | 10:26 PM
rovigian's Avatar
Default Re: Yeah, another PS removal post (yeegsr)
On my car 94 gsr I just removed the pump and belt and left the hoses sitting there.
And all of the fluid shot out already. Is that bad for the steering assembly, or will it cause damage?
IemSpooled219
Nov 8, 2009 11:20 AM
Corksil
Aug 13, 2009 08:20 PM
yeegsr
18
Nov 2, 2004 10:55 PM
yeegsr
Oct 27, 2004 02:48 PM
