removing gas tank NEED HELP FAST
Old Oct 27, 2004 | 08:35 AM
Layziebtnh055's Avatar
Default removing gas tank NEED HELP FAST
im trying to drop my gas tank, i draind it, took the 2 strraps off and it wont come down what else is holding it
Old Oct 27, 2004 | 08:41 AM
HOND PWR's Avatar
Default Re: removing gas tank NEED HELP FAST (Layziebtnh055)
Filler neck (where you put gas in)?? I had to remove that to drop my tank enough to replace the fuel pump.
Old Oct 27, 2004 | 08:42 AM
Turbo88hatch's Avatar
Try removing all of the hoses as well as the metal thing where you fill the tank at.Also be sure to all of the wires going to the tank.
deftones0817's Avatar
pull the center piece in the crx out you have to unplug the gas sending unit in the back of the car from inside. It has one or 2 wires and 3 screws i believe.
DEF
Old Oct 27, 2004 | 09:26 AM
Default Re: removing gas tank NEED HELP FAST (HOND PWR)
it feels like it is stuck on the passenger side on somethings not the filler neckat all
Old Oct 27, 2004 | 09:49 AM
bbbb
Old Oct 27, 2004 | 11:14 AM
bump
Old Oct 27, 2004 | 11:46 AM
civickiller's Avatar
can it move around like just something is holding it from coming out, or is it still stuck and it cant move like something is still mounted on the tank ?
when i took my gas tank out to change my fuel pump, took out filler neck, disconnected all fuel lines, sending unit, took straps off and the tank came down. getting it back up was a bitch.
but i also remember having to take or loosen something on the front passenger side of the tank, but i forget what it was
Old Oct 27, 2004 | 11:56 AM
tgreaves's Avatar
Default Re: removing gas tank NEED HELP FAST (civickiller)
Mine was stuck to the undercoating of the car.. But if its loose and isng comming down then something else might be holding it.. Did you unplug the harness going to it?
Old Oct 27, 2004 | 12:27 PM
Default Re: removing gas tank NEED HELP FAST (tgreaves)
the dirvers side part of the tank is free it feels loose its the other side of the tank wont budge
Old Oct 27, 2004 | 12:38 PM
baha_boy's Avatar
you have to remove the pump from the top of the tank first. remove the straps and then the pump then the tank drops i put a pump in my 91 civic hatch
sc0braj
Aug 18, 2008 08:15 AM
folta2169
Jul 31, 2007 12:53 PM
HondaHemi
Dec 3, 2005 05:51 PM
null.
Jun 22, 2005 07:03 PM
Hard2Find
Aug 16, 2004 08:47 PM
