Anyone have a trunk popper?
Old Oct 26, 2004 | 09:11 PM
DIYaccord's Avatar
Default Anyone have a trunk popper?
Does anyone have any pictures of how you have you're silinoid attached.
I got one for my alarm and and trying to figure out how to attach it in the trunk.
Help
-Nick
Old Oct 26, 2004 | 11:39 PM
iam7head's Avatar
Default Re: Anyone have a trunk popper? (DIYaccord)
it's all integrated to one unit, there's a door handle(prevent you from kidnapping hookers or alike), a remote controlled motor which slide the handle, and there's a cable run to it from the driverside trunk release.
need pic?
Old Oct 27, 2004 | 08:08 AM
DIYaccord's Avatar
Default Re: Anyone have a trunk popper? (iam7head)
sure, why not...
but i'm really looking for some pictures of actually peoples setups
Old Oct 27, 2004 | 07:49 PM
DIYaccord's Avatar
anyone?
Old Oct 28, 2004 | 07:21 AM
Heat's Avatar
I'm not quite sure what you're asking about, but here are the installation instructions for a trunk opener for a 6th gen.:
http://www.handa-accessories.c...r.pdf
Old Oct 30, 2004 | 08:05 AM
DIYaccord's Avatar
Default Re: Anyone have a trunk popper? (Heat)
not quite bur getting there
here's a pics of what a i have:
except mine didn't come with that piece of black tubing
Old Oct 31, 2004 | 01:17 AM
z168's Avatar
The motor you will align parallel to the part where the cable pulls the trunk open. So when you activate the solenoid it pulls the cable opening the trunk.
Typically you would hook this up to your alarm right? so ditch the push button switch you have included. the bracket you would know what to do. the relay and hook up to your alarm is basic stuff for your electrician
where did you get yours? how much was it and whats the brand you got?
Thanks
Old Nov 1, 2004 | 08:23 AM
DIYaccord's Avatar
Default Re: Anyone have a trunk popper? (z168)
lol...I'm not that much of a n00b
I just wanna see how people have them set up in a 5th gen accord to get an idea of how I can mount mine
I got mine from my work (radioshack) for $15
Old Nov 4, 2004 | 02:54 PM
z168's Avatar
lol :D
if youre familiar with DIY then that should be easy. ill check our local radio shack if they have it and ill get myself one
Old Nov 4, 2004 | 06:59 PM
TekSI's Avatar
i did it in my g/f's 90 accord. i pretty much screwed the solenoid to the crossmembers under the trunk lid. the solenoid i bought from http://www.allelectronics.com had a little 3screw adapter that i put onto the rod that connects to the lock. then connected the rod of the solenoid to that, ran wires to the keyless unit. doesn't work by remote right now because i needed a relay, which i'm installing this weekend, but i hardwired it and it works fine. i can take pics this weekend if you want
Old Nov 4, 2004 | 07:19 PM
pyrojeff's Avatar
Default Re: Anyone have a trunk popper? (TekSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TekSI &raquo;</TD></TR><TR><TD CLASS="quote">i did it in my g/f's 90 accord. i pretty much screwed the solenoid to the crossmembers under the trunk lid. the solenoid i bought from http://www.allelectronics.com had a little 3screw adapter that i put onto the rod that connects to the lock. then connected the rod of the solenoid to that, ran wires to the keyless unit. doesn't work by remote right now because i needed a relay, which i'm installing this weekend, but i hardwired it and it works fine. i can take pics this weekend if you want</TD></TR></TABLE>
I'm interested. Thinking about doing this on my '94.
Old Nov 4, 2004 | 07:30 PM
TekSI's Avatar
i'll take pics this weekend, let see how i did it
BlackEyeRed
Sep 27, 2012 08:11 AM
DaGlitch
Audio / Security / Video
Aug 20, 2007 04:44 PM
4doorex
Nov 4, 2004 06:25 AM
built562
18
Apr 21, 2003 11:35 PM
dgdarien
Dec 22, 2002 09:54 AM
