For a 92 civic, I'm installing a obd1 jdm gsr, and I'm wondering, what is required for the wiring?
If you can help me out that would be awesome, thanks alot, also if you know of any online install guides, that could really be helpfull.
What motor are you using, which ecu and what model of a 92 Civic is it going in? If it's and OBDI ecu, the car harness will plug in. Without knowing the type of setup you are using, it's hard to say what kind of wiring job you'll be looking at.
i actually have the exact same set up as you. 1995 civic vx with an jdm obd1 gsr motor the ecu is one one that originally came out with the motor in japan so i assume it is the p72
thanks guys !
[Modified by Matty Devine, 6:36 AM 12/20/2001]
thanks guys !
is there any place i can see a list of everything i need for the swap i know the big things are covered but i need to know more about the small things like fuel pumps and fuel pressure regulators
is there any ;lists out there or could someone who has done this tell us everythig they used
thanks
thanks
here you biatches go
http://www.c-speedracing.com/howto/b18cswap/swap.html
Jaime Sanchez
Oct 26, 2018 10:43 AM
IS3Fifty
Mar 22, 2003 10:33 AM
