GSR "cuts out" or "hiccups" when stomping gas, what the heck?
Old Oct 25, 2004 | 08:27 PM
CrazyModGSR's Avatar
Default GSR "cuts out" or "hiccups" when stomping gas, what the heck?
I bought my turbo '94 GSR last April, no problems really. One thing that I have noticed happening a few times, and again today is that it seems to cut out for a second or hiccup you may say. For instance, say I am in third driving about 30 mph at about 3500 rpm or so. I stomp the gas to pass some cars, and when it hits around 5k rpm or so, it kind of loses power or hiccups for a second. It immediately lean off the throttle a little bit when this happens. Not sure why this is happening, but I want to figure it out. Has also happened at about 120 mph on the highway under high throttle (a few occurrences). Don't know if this could be the governer, but never had a problem getting past 120+ in my old 94 GSR. Any suggestions. The car has a full turbo setup. I am wondering if the problem could lie in the fuel pump or something. Has an external inline fuel pump.
Old Oct 26, 2004 | 10:49 AM
Default Re: GSR "cuts out" or "hiccups" when stomping gas, what the heck? (CrazyModGSR)
bump
Old Oct 26, 2004 | 11:05 AM
aznballer's Avatar
maybe bad spark, not sure but u could check that
Old Oct 26, 2004 | 11:09 AM
95 integra's Avatar
Default Re: (aznballer)
it could be several things, but generally thats what happens when a car is running really rich.
Old Oct 26, 2004 | 11:39 AM
hott-nix's Avatar
Default Re: (95 integra)
i have a bone stock gs-r and mine was doing the same thing.
i think it has to do with oil pressure and the vtec pressure switch.
check your oil level to start. check and clean your vtec sol. and pressure switch
i added some oil to the full mark and it solved all my problems, though it could be somehting else
Old Oct 26, 2004 | 11:42 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (hott-nix)
Maybe you shouldn't be doing 120 on the highway?
Old Oct 26, 2004 | 11:54 AM
Brand's Avatar
my car started doing that today too... did ur car kind of jerk back n forth?
Old Oct 26, 2004 | 01:06 PM
iiilgsrlll's Avatar
How much boost are you running? Fuel management? Do you have a boost gauge?
If you are running the stock MAP sensor and boost exceeds its threshold you are going to hiccup exactly how you're describing. How do I know? I had the same issue. My boost would spike under high load (freeway boosting) beyond what the stock MAP sensor (around 10.84 psi) could read so it cut fuel. I didn't know why either until Shawn Church saw what was happening on the dyno.
Old Oct 26, 2004 | 08:37 PM
Default Re: GSR "cuts out" or "hiccups" when stomping gas, what the heck? (iiilgsrlll)
i currently don't have an oil pressure gauge installed. i have it and will install it while car is garaged for winter (mid Nov to March). boost gauge is installed, and reads fine. i know the car has the missing link, re: map sensor. i have an apexi s-afc, which I have not played with at all. same settings as when I bought the car (also, if the neg or pos terminal comes off the battery, the s-afc will remember settings correct? because power has been disconnected many times.) vortec fmu. 7 psi of boost.
Old Oct 26, 2004 | 09:00 PM
Oleg's Avatar
i think that it might be defective throttle position sensor, ti might be open at a sertain position, and it does not depend on speed, only on your gas pedal position........ it is a variable fesistor, they go bad with time.....
Old Oct 26, 2004 | 09:02 PM
Default Re: GSR "cuts out" or "hiccups" when stomping gas, what the heck? (Oleg)
how would I know if it is this though. i hate to spend the money on all these different things not knowing exactly what it is
Old Oct 26, 2004 | 09:28 PM
iiilgsrlll's Avatar
If you're running the missing link then please disregard the MAP sensor.
MAP sensor wouldn't be causing the problem if it isn't seeing any positive pressure.
Old Oct 26, 2004 | 09:43 PM
Oleg's Avatar
troubleshoot it.......get the electrical diagram, multimeter, and go for it , connect so that you can measure the resistance , sweep throttle from idle pos. to WOT (with the engine off key on) and see if the resistance shanges gradually. if it doesn't then the sensor is bad.........get an acces to All Data, all the info is in there, or hanes manual.
Old Oct 26, 2004 | 10:27 PM
mrDFWmechanic's Avatar
would it be a fuel problem at all ??? just my 2cents worth
Old Oct 27, 2004 | 05:44 AM
Default Re: (iROCKtheSOHC)
like i mentioned, i thought it may have something to do w/ the fuel pump or injectors or something. although the vtec solenoid theory might be something, as the problem always seems to occur around 5k rpm, just about when vtec is kicking in
Old Oct 27, 2004 | 08:21 AM
PredatorGSR's Avatar
I had the same problem I believe. It culminated in the car finally taking forever to start. I used a multimeter to test the connections in the distributor, and found a bad connection between the ignitor and coil. I replaced the ignition coil and the ignitor, but it didn't seem to help. I said **** it and started driving again anyway, and slowly the problem went away and was gone a week later. Its been 4 months, and it hasn't had a problem. So i'm not really sure what to tell you, check all the connections inside the distributor.
Here is a thread on how to do it on Team-Integra.net. http://www.team-integra.net/fo...earch
The answer is explained on the second page.
Old Oct 27, 2004 | 01:13 PM
B-money's Avatar
Default Re: (PredatorGSR)
if your car is bone stock, you might want to check out your air filter. If it's dirty replace it.
Old Oct 27, 2004 | 01:24 PM
boosted k20's Avatar
Default Re: (B-money)
do u have an external coil? my friends Blaster 2 coil went bad and it made his car sound like it's gargling/hiccup sound when u give it gas. swapped the coil and the car ran really good
kayley94
Jun 17, 2019 07:25 PM
Joshbreeezy
Sep 24, 2017 04:48 PM
AZDB8
Nov 17, 2006 02:24 PM
MajorPayne
Feb 23, 2004 04:27 PM
b18bEG
Nov 7, 2002 06:49 PM
