my rc 750's will not fit
ok i bought rc 750 injectors and they dont fit i got them in the fuel rail aem fine but when i go to bolt them in to the intake manifold with those 3 bolts the bolts arent even come throught the holes on the fuel rail
you will be ok they won't have to be all the way in on the intake manifold side all they have to do is press alittle bit against the black o-rings just take the three studs out place a nut on them then extend them until you could get the nut on the rail with some threads showing, and then tighten the nut against the intake manifold and then the nuts holding the rail down and you will be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">or take the stud out of the manifold and go to lowes and get a bolt i had to do the same thing, also you may need to drill out the lower gromets to seat the injectors lower</TD></TR></TABLE>
like what he said. bore out the bottom seals. i took a strip of sand paper a cotter pin and a drill and bored mine out
i had to do the same thing to my 440's. not too much work involved.
aemciv
Mar 24, 2003 11:34 PM
aemciv
Mar 24, 2003 10:54 PM
Quik Chris
Sep 27, 2002 09:04 PM
