uberdata bin file for t3/t4 turbo
i currently am running a d16z6 w/ ob1. i was wondering if anyone is running a t3/t4 turbo, if so i would like to have their bin file so i could use it for my base map.
Make your own, but look off a good one from uberdata just to make sure you have the idea of things. You always want to make your own, that is the only way you will be sure it is ok. Start by using "the how to make a base map" from keeblers website. Search Uberdata forum to find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">You always want to make your own, that is the only way you will be sure it is ok. </TD></TR></TABLE>
No, you always want to tune your basemap, because if you don't it is most definitely NOT okay.
And I was saying that someone else's basemap might be retartded or send you the wrong one, saying that it is the only way you know it is ok, is saying that you did the map not some one else. Its ok if it runs and its rich, you can most definitley drive it, seeing that its not even close to as bad as the hack....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 »</TD></TR><TR><TD CLASS="quote">well i just want somone that has a bin file so i can start tuning it from there. i wasn't going to load it up and just leave it.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">Make your own, but look off a good one from uberdata just to make sure you have the idea of things. You always want to make your own, that is the only way you will be sure it is ok. Start by using "the how to make a base map" from keeblers website. Search Uberdata forum to find it.</TD></TR></TABLE>
Reading comprehension, bro...
I read that much, I was refering to what you didn't comprehend about what I said earlier.. its cool. Make a basemap and get it tuned, do it yourself, it is a good learning experience. Is that a good answer then?
