Low compression numbers.
Wassup guys, I did a compression and the number were very low.
Cyl 1- 140
Cyl 2- 80
Cyl 3- 40
Cyl 4- 120
My car is running fine, there no oil in coolant, gas mileage still great, my car has 80 thousand miles on it, recently adjust valve to see if it was cause of low compression, and doesn't burn any oil.
Something might be wrong with my engine though because even though it is running fine, there are brief momentarily times when it does not. Maybe once a week, my cel would come on for misfire on cyl 3 and the cause of that would be heavy sputtering at idle. But then, when the sputtering goes away my cel light would dissapear also.
Cyl 1- 140
Cyl 2- 80
Cyl 3- 40
Cyl 4- 120
hondaeg8
10
Jul 25, 2004 11:13 AM
